03-25-2015 09:26 AM - edited 03-18-2019 04:14 AM
I have vcs expressway in our dmz, vsc controller inside (X8.5.1), to mcu 5310 on 4.5(1.55).
External Polycom HDX calls work fine, but if they come in Polycom Group 500, we receive video but no audio, and there is no audio or video out to the external connection.
Polycom Group 500 calls internally to vcs controller or mcu have two-way video, audio from the mcu, but no audio from Polycom.
Any pointers on this would be appreciated.
Thanks!
03-26-2015 02:21 AM
What software revision is the Polycom on?
Cheers
Chris
04-07-2015 10:25 PM
We don't have any Polycom Group Series in our environment as they can't be managed by TMS, but from previous experience with other Polycom endpoints (VSX/HDX), it's either a network issue (as suggested by Chris), or a Capset negotiation, Polycom software or configuration issue.
Some quick (non-network) things that spring to mind to check:
Otherwise, you'll need to start looking at your network (as mentioned by Chris, a better idea of your topology can help us to point you in the right direcction) as it's likely an issue caused by one of the devices between the endpoints. If you have the time and skills, getting a Wireshark in between the devices can help greatly in seeing the traffic flow and signalling that may cause the one-way audio/video issue.
I'd also suggest that you post a similar thread over on the Polycom support communityas people over there are more likely to have a deeper insight in to how the Polycom devices operate. Please feed back here any insight or solution you find from there (or a link to your thread) to help any others who may have a similar issue in the future.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
