09-11-2013 12:28 PM - edited 03-18-2019 01:47 AM
Upgraded a court room from Edge 95 with ISDN to SX 20 and ISDN Link. Previously the court communicated IP to local endpoints and ISDN to several Polycom Bridges nationally. SX 20 works great IP but will only connect to a Cisco Bridge (our test brige in Toronto) but not to the Polycom bridges that they use to. Changed Capset per TAC instructions after providing configs, only to get video on one bridge but no audio. After weeks of trying this and that TAC wants us or the customer to find a Polycom bridge and engineer to record what is happening at the far end. Why are we doing the R &D on this equipment, why doesn't Cisco arrange the connection with a Polycom engineer.
09-11-2013 09:25 PM
There's a bug in TC6.1.x and TC6.2.0 talking to Polycom end points and bridges that stops video or audio from working (See bug CSCuh27649).
This is resolved in TC6.2.1 due out in the next week or so.
As a work around, we've found that downgrading to TC6.0,1 or using SIP rather than H.323 is a workaround. Not sure if that'll help with your ISDN link though. You might just have to hang out for the fixed firmware.
Please remember to mark helpful responses and to set your question as answered if appropriate.
09-11-2013 09:59 PM
Hi Bob,
Further to what Wayne said. If you have a TAC case already open you can request the TC 6.2.1 software even though not released yet. The TAC engineer will send you a download link.
I received the software last week to fix some other issues i had with 6.2
09-11-2013 10:10 PM
I was told today that "TC6.2.1 is going to release next week", so unless it's extremely urgent that you upgrade for your issue, it may not be worth the trouble of going through TAC.
But, if your problem is urgent, then yes, as above, please contact the TAC and request a copy. I've had a couple of different versions of TC6.2.1 over the last few weeks which have been addressing multiple issues I've had in TC6.1.x and TC6.2.0.
09-12-2013 12:14 AM
Hopefully going through TAC is not too troublesome
//Marius
09-12-2013 08:06 AM
Thanks everyone, contacted the person working on our ticket and just waiting to received the Latest release.
09-12-2013 12:17 AM
Send me a private message with your CCO-account - and I will be able to release the newest beta/version on cisco.com for you to test in your lab/equipment.
Please note that that what I will release for you is not a finalized software and should only be used for testing purposes.
//Marius
09-16-2013 08:14 AM
My partner installed the new release last friday and after hours of resets and changes with the codecs network programming the link and codec finally talked to each other and to the network. Today he is testing to a polycom bridge via ISDN and we only get video from the far end no audio, the far end gets no video or audio. He added the previous capset filter and we get the same results. All IP and ISDN calls to other Cisco endpoints work great. Any suggestions..
