Number of congruent interop calls between CUVC & CTMS
Anand Kochhar
How may number of simultaneous interop conferences possible between a single CTMS and the CUVC (SD/HD)?
To have second simultaneous interop call, do I need to have another set of CTMS & CUVC?
Rgds,
Anand
gogasca
Level 10
Level 10
That will depend mostly of CUVC ports resources
The capacity for number of videoconferencing endpoints is dependent on the port capacity of the CUVC.   The 3515 has 12 port and 24 port models.  The 3545 support a maximum of 24 ports in a single meeting.  Since the linkage (cascade) between CTMS and CUVC is 1 CTMS segment and 1 CUVC port per meeting, the maximum number of VC endpoints on a 3515/12 is 11, and the maximum for a 3515/24 or 3545 is 23
Thx for brining technical clarity on interop.
Is this feature for “more than one simultaneous/congruent interop” is open to all partners/dealers, or it is exclusive to certain MSCP partners for certain period?
rgds,
Anand
