Old Border Controller Kernel problem
david.sharp
Hi Cisco Support Community
Does any one know what the following error messages mean from a Tandberg classic border controller?
Oct 5 14:01:06 vale-bc syslogd 1.5.0: restart.
Oct 5 14:01:06 vale-bc root: Event="System   Start" Level=1 UTCTime=2012/10/05-14:01:06
Oct 5 14:01:06 vale-bc kernel: ERROR: Unable to   locate IOAPIC for GSI 8
Oct 5 14:01:06 vale-bc kernel: ERROR: Unable to   locate IOAPIC for GSI 13
Oct 5 14:01:06 vale-bc kernel: ERROR: Unable to   locate IOAPIC for GSI 6
Oct 5 14:01:06 vale-bc kernel: ERROR: Unable to   locate IOAPIC for GSI 4
Oct 5 14:01:06 vale-bc kernel: ERROR: Unable to   locate IOAPIC for GSI 3
could we maybe recover the border controller via root, software recovery or is the kernal error referencing a hardware failure.
Cheers
Dave
Think with Portals
Think with Portals
6 Replies 6
Dharmesh Nandoria
Hi Dave,
Device is having 2 software images , You can try to swap software image . Procedeure is given on page 20-21.
https://supportforums.cisco.com/docs/DOC-15644
Kind regards,
Dharmmesh
Hi Dharmesh
thanks for providing this information, i have noticed that in the document on the pages you mention the document is talking about the VCS, the border controller in this instance is not a VCS, this is one of the Tandberg Classic border controllers before the VCS was developed, does the same procedure still apply?
Cheers
Dave
Think with Portals
Think with Portals
Having read https://patchwork.kernel.org/patch/110922/ I think this is nothing to worry about.
We also have this output in our dmesg from our Border Controller:
pnp 00:03: [io  0x0070-0x0073]
pnp 00:03: [irq 8]
pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:04: [io  0x0061]
pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
pnp 00:05: [io  0x00f0-0x00ff]
pnp 00:05: [irq 13]
pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:06: [io  0x03f0-0x03f5]
pnp 00:06: [io  0x03f7]
pnp 00:06: [irq 6]
pnp 00:06: [dma 2]
pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
pnp 00:07: [io  0x03f8-0x03ff]
pnp 00:07: [irq 4]
pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:08: [io  0x02f8-0x02ff]
pnp 00:08: [irq 3]
pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:09: [io  0x0378-0x037f]
ERROR: Unable to locate IOAPIC for GSI 7
pnp 00:09: [irq 7]
pnp 00:09: Plug and Play ACPI device, IDs PNP0400 (active)
Dharmesh Nandoria
Hi Guy,
Procedure is same for BC .
Kind regards,
Dharmmesh
Dharmmesh, I support BC - this is not a problem.
Hi Dharmesh
This is good news, we shall give this a go.
Cheers
Dave
Think with Portals
Think with Portals
