Beginner
Outbound calls ceased
All, Ive been working with my VOIP lab and until recently I have been able to make calls both in and out. Inbound calls still function but outbound calls have stopped. I was working with the router a little last night and I might have broken something but I can't seem to find it. If anyone can spot where I've gone off trail I would appreciate it.
When I attempt to dial out the phone takes the number, shows "Ring Out" and then the call times out and drops.
My CME is a 3725 router running 12.4 code.
The current configuration:
boot-start-marker
boot system flash
boot-end-marker
no aaa new-model
clock timezone Eastern -5
no network-clock-participate slot 1
ip cef
no ip domain lookup
voice-card 1
no dspfarm
interface FastEthernet0/0
description To ASA
ip address 192.168.1.100 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
tftp-server flash:P0030801SR01.loads
tftp-server flash:P0030801SR01.sb2
tftp-server flash:P0030801SR01.sbn
tftp-server P0030801SR01.bin
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:RingList.xml
tftp-server flash:Bass.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
control-plane
voice-port 1/0/0
connection plar 1001
description Obi xxx.xxx.9501
voice-port 1/0/1
dial-peer voice 1 pots
description PSTN
destination-pattern 9T
port 1/0/0
forward-digits 11
dial-peer voice 1001 voip
description Line 1001
destination-pattern 1001
telephony-service
load 7960-7940 P0030801SR01
max-ephones 20
max-dn 48
ip source-address 192.168.1.100 port 2000
system message Exarch Net
time-format 24
create cnf-files version-stamp 7960 Sep 22 2012 23:01:55
max-conferences 8 gain -6
secondary-dialtone 9
directory entry 1 1001 name Adam
ephone-dn  1  dual-line
number 1001
ephone-dn  2
number 1002
ephone-dn  3
number 1003
ephone-dn  4
number 1004
ephone  1
description Office 1
mac-address 0002.FD65.9E85
type 7960
button  1:1 2:2 3:3 4:4
ephone  2
description Office
mac-address 0011.93F6.6D95
type 7940
button  1:2 2:1
ephone  3
description Downstairs Phone
mac-address 0012.8055.CEF3
button  1:3 2:1
line con 0
line aux 0
line vty 0 4
password 7 140413091E017C6D62
login
ntp master
Thank you all!
Everyone's tags (1)
1 REPLY 1
Beginner
Re: Outbound calls ceased
Ok, after a reload the call manager is still not connecting outbound calls. Here is the output from the debug (I changed the first 6 digits of the phone number to x)
Nov  2 17:17:27.423: //-1/xxxxxxxxxxxx/DPM/dpCheckTerminationStatus:
   Connection mode is not normal
Nov  2 17:17:27.423: //-1/xxxxxxxxxxxx/DPM/dpSendTransitionEvent:
   sending 0x10 event
Nov  2 17:17:32.847: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1001, Called Number=, Voice-Interface=0x6497B3E4,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_ANSWER; Calling Number=1001
Nov  2 17:17:32.847: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Nov  2 17:17:32.847: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=1001T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Nov  2 17:17:32.847: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5406
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=1001
Nov  2 17:17:32.847: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=20001 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
Nov  2 17:17:32.847: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@5940
Nov  2 17:17:33.359: //-1/05D3598D8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1
Nov  2 17:17:33.359: //-1/05D3598D8026/DPM/dpMatchCore:
   Dial String=1, Expanded String=1, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  2 17:17:33.359: //-1/05D3598D8026/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=20001
   Result=1
   Result=Partial Matches(1) after DP_MATCH_DEST
Nov  2 17:17:33.359: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
Nov  2 17:17:33.611: //-1/05D3598D8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=17, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=17
Nov  2 17:17:33.611: //-1/05D3598D8026/DPM/dpMatchCore:
   Dial String=17, Expanded String=17, Calling Number=
Nov  2 17:17:33.611: //-1/05D3598D8026/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=1
   Result=1
Nov  2 17:17:33.611: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=170, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=170
   Dial String=170, Expanded String=170, Calling Number=
   Result=1
Nov  2 17:17:33.863: //-1/05D3598D8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1706, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1706
Nov  2 17:17:33.863: //-1/05D3598D8026/DPM/dpMatchCore:
   Dial String=1706, Expanded String=1706, Calling Number=
Nov  2 17:17:33.863: //-1/05D3598D8026/DPM/MatchNextPeer:
   Result=1
Nov  2 17:17:33.863: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=17062, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=17062
   Dial String=17062, Expanded String=17062, Calling Number=
Nov  2 17:17:33.867: //-1/05D3598D8026/DPM/MatchNextPeer:
Nov  2 17:17:33.867: //-1/05D3598D8026/DPM/dpMatchCore:
   Result=1
Nov  2 17:17:33.867: //-1/05D3598D8026/DPM/dpMatchPeersCore:
Nov  2 17:17:33.867: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=170623, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=170623
   Dial String=170623, Expanded String=170623, Calling Number=
   Result=1
Nov  2 17:17:34.119: //-1/05D3598D8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1xxxxxx, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1xxxxxx
Nov  2 17:17:34.119: //-1/05D3598D8026/DPM/dpMatchCore:
   Dial String=1xxxxxx, Expanded String=1xxxxxx, Calling Number=
Nov  2 17:17:34.119: //-1/05D3598D8026/DPM/MatchNextPeer:
   Result=1
Nov  2 17:17:34.119: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=1xxxxxx7, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1xxxxxx7
Nov  2 17:17:34.123: //-1/05D3598D8026/DPM/dpMatchCore:
   Dial String=1xxxxxx7, Expanded String=1xxxxxx7, Calling Number=
Nov  2 17:17:34.123: //-1/05D3598D8026/DPM/MatchNextPeer:
   Result=1
Nov  2 17:17:34.123: //-1/05D3598D8026/DPM/dpMatchPeersCore:
Nov  2 17:17:34.123: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
Nov  2 17:17:34.371: //-1/05D3598D8026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1xxxxxx70, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1xxxxxx70
Nov  2 17:17:34.371: //-1/05D3598D8026/DPM/dpMatchCore:
   Dial String=1xxxxxx70, Expanded String=1xxxxxx70, Calling Number=
Nov  2 17:17:34.371: //-1/05D3598D8026/DPM/MatchNextPeer:
   Result=1
Nov  2 17:17:34.371: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=1xxxxxx700, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1xxxxxx700
   Dial String=1xxxxxx700, Expanded String=1xxxxxx700, Calling Number=
Nov  2 17:17:34.375: //-1/05D3598D8026/DPM/MatchNextPeer:
Nov  2 17:17:34.375: //-1/05D3598D8026/DPM/dpMatchCore:
   Result=1
Nov  2 17:17:34.375: //-1/05D3598D8026/DPM/dpMatchPeersCore:
Nov  2 17:17:34.375: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Calling Number=, Called Number=1xxxxxx7009, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1xxxxxx7009
   Dial String=1xxxxxx7009, Expanded String=1xxxxxx7009, Calling Number=
   Result=Success(0); Outgoing Dial-peer=1 Is Matched
   Result=Success(0) after DP_MATCH_DEST
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  2 17:17:34.379: //-1/05D3598D8026/DPM/dpMatchPeersCore:
Nov  2 17:17:34.379: //-1/05D3598D8026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Content for Community-Ad
August's Community Spotlight Awards
