219
jvodny
Beginner
Packet marking verification of outgoing packets for Immersive Endpoints TX, CTS Series
Is there any way how to verify outgoing packet marking from TX and CTS Immersive systems on the system itself please?
Can I find it somewhere in the logs? In which one please?
I can see packet marking for incoming packets in Call Statistics but not for outgoing packets.
CUCM config is EF for voice and AF41 for Video (verified at Telephony Settings) but I can see both audio and video incoming packets on other site as AF41.
Any answer really appreciated.
Josef
1 ACCEPTED SOLUTION
Martin Koch
Advocate
As Chris said, use something with port mirroring to be sure.
There is also a capture cpapability on the CTS / TX systems, please see the cli guide
utils network capture
utils network capture [dest ip-address-or-hostname]
host [ ip | arp | rarp | tcp | udp | all]://ip-address-or-hostname] [page][numeric][hex][file][count number][size number][port number] [src ip-address-or-hostname]
Syntax Description
count number dest
ip-address-or-hostname file
hex
host
protocol://ip-address-o r-hostname
numeric page
port
number size number
src
Optional. Number count of packets to capture. Maximum count is 1000 for file, 10000 for screen.
Optional. Source address of the packet as a dotted IP or hostname.
Optional. Sends capture output to a file (netCapture).
Optional. Shows output in hex and ascii.
Optional. The all keyword specifies all protocols. ip-address-or-hostname is the host address of the packet and can be a dotted IP or hostname. The :// is required between the protocol and IP address or host name.
Optional. Show hosts as dotted IP addresses.
Optional. Pauses output.
Optional. Port number of the packet (either src or dest).
Optional. Number of bytes of the packet to capture. Maximum size is 1024. Optional. Source address of the packet as a dotted IP or hostname.
3 REPLIES 3
Chris Swinney
Contributor
I know this is not exactly what you asked for, but I would be inclined to either mirror a port on the connected switch, or add network tap in line from the systems. This is the only way to be sure what is on the network.
Cheers
Chris
Martin Koch
Advocate
Syntax Description
count number dest
hex
host
numeric page
port
number size number
src
jvodny
Beginner
Thanks Martin,
That is I was looking for. I supposed it could be used on via root account and have not checked it.
Josef
Create
Recognize Your Peers
Content for Community-Ad
