Part code lookup
jacinto1m
I was given the serial numbers of various Cisco Telepresence devices but need to find out what devices those are.
Is there any tool to find out the part code of a Cisco device from the serial number?
Any help is much appreciated.
2 Accepted Solutions
Tomonori Taniguchi
Try this by using Cisco Product License tool, https://tools.cisco.com/SWIFT/LicensingUI/tandbergLicenseLookup.
Enter serial number and keyword display in windows then click “search” should display system information.
T880 MXP is CTS-880-PAL (113560P, 113560CN - 880 MXP PAL) and this include 1138352.
7 Replies 7
Tomonori Taniguchi
Tomonori Taniguchi
Other quick method to check system model is to look first a couple digit of serial number.
Serial Number starting with...(as example);
  • 25A: MXP Endpoint
  • A1AA: E20
  • F1AN: C20
  • B1AV or F1AV: C40
  • B1AD or F1AD: C60
  • B1AC: C90
  • A1AZ: EX60 / MX200
  • A1AR: EX90
  • A1AS: Touch Panel
  • A1AT: PrecisionHD 4x
  • A1AB or B1AB: PrecisionHD 12x
    etc.
Thanks a lot Tomonori.
One more question, is the Tandberg end point below EOS?, I couldn't find any EOS announcement for this specific model.
TANDBERG 880 MXP 384 kbps ISDN/1.1 Mbps IP
Quantity
SC#
SC End
LIC-S50000-K9:
S50000:SW PAL/NTSC for MXP
F6.1
113825MS:
113825MS:880 MXP MS option
1138352:
1138352:880 MXP Bandwith option 384k ISDN/1.1M I
L-SET770TO880:
11389011:880 MXP Settop Version key
But this specific model:
1138352
Isn't in that list.
Perfect!
Thanks a lot.
