PC to EX90 cable
Daniel Gomez
I will be probably a very basic question but does anybody know if there is any part number we can order from Cisco in order to get the DVI-I to VGA cable included with the EX90?
We're having some troubles with the current one and we need to buy some new.
On the datasheet we see it says: VGA-to-DVI-I cable but we have been unable to find or order it.
Thanks.
2 Accepted Solutions
amehla
Hi Daniel,
the presentation cable shipped with EX90 has Part ID
CAB-DVI-A-VGA125=
As VGA is only analog the digital part would not be used anyhow, so it would not matter
if there is a DVI-I or -A plug on the cable. It would only be an issue if the device you
try to connect to would only have a DVI-A connector, but as the codec is -I its no issue :-)
Did I understood your question right or why did you wonder about -A vs. -I
amehla
Hi Daniel,
CAB-DVI-A-VGA125=
Hello Amit,
Thanks for you answer.
Do you know if there is any document showing this is the cable? I see datasheet says DVI-I and part number says DVI-A.
Thank you all.
