331
CaliHC
Beginner
PHD1080p12x not found by codec
i have several PHD1080P12X Cams here and a C40 codec.
all cams but one is found by the codec if i directly connect the cam to the codec.
the one that is not found by the codec can be controlled via serial by a visca serial controller.
another problem is that this cam only gives out video on the hdmi connector, the sdi connector is dead.
all other cams are working as expected.
Perhabs someone have a hint .
1 REPLY 1
CaliHC
Beginner
please nobody any idea?
i really would like to flash the firmware on that cam.
but i cant via the codec because the cam is not found.
I could flash it directly over serial and ethernet but i need the rover.pkg for that.
Create
Recognize Your Peers
Content for Community-Ad
