Can somebody please provide us the power consumption by TANDBERG C40, C60, 1700MXP and SX20 in Active and Standby mode.
We have a testing scheduled and need this for comparision.
Kindly help ASAP.
Akshay
Solved! Go to Solution.
Hi Akshay,
Please download the document from this link which will give you detailed information on the power consumption of the Tandberg device : http://www.mediafire.com/view/?pb6bk7gcp30kb0r
Prashant Rawat
Hi Akshay,
Prashant Rawat
Hi Prashant,
Not able to access the file as it is showing Invalid or Deleted file when going to the above mentioned link.
Hi Akshay,
Hope it helps.
Prashant Rawat
Hi Prashant,
Thanks for your help and prompt reply.
Akshay
Could you please share latest update for below endpoints.
MX300 G1 and G2
MX200 G1 and G2
SX80
EX90
Refer to the technical specifications contained within each of the product's administrator guides. For example, an SX80 under normal operating conditions is 99 W, seen in the SX80 CE8.2 Admin Guide on pg 179.
Thanks Patrick!
What is the power consumption in sleep mode?
I do not know, and unfortunately not all the guides mention the power used in sleep mode, I believe the EX90 guide does, not sure about the others.
