Hello
I need to connect a precision hd 720p cam to mxp edge 95 codec. Made a cable using the pinouts mentioned in camera guide but I got no video but camera is powering on and I am able to control it too via it's IR sensor. If anyone can help me with this and give me the correct pinouts for both ends RJ45 at camera and DB9 at Codec I would be very thankful.
Hi Mubashir,
please find the following Pin-outs for the camera port for the Edge
Dean.
Hi Mubashir,
I forget to mentioned, The Edge is using the same camera cable as for the 3000 MXP
tsee below the data port pin out, I hope this will help you to solved your issue :
Dean.
thanks dean,
I am a bit confused is this pinout is for the RJ45 end ?? or the DB9 (main cam) end. Cause I need both end pinouts.
like
RJ45 --------> main cam port (DB9)
pinouts ------> pinouts
