01-23-2019 09:51 AM - edited 03-18-2019 02:36 PM
Does anyone know if you can use the PrecisionHD 12x Camera's with the new WebEx Kit Plus & Pro models? I'm trying to see if we can recycle the cameras for another year or two.
Solved! Go to Solution.
01-23-2019 09:56 PM
As per the release notes it is not supported-
Thanks.
Please rate if it is helpful....
01-23-2019 09:56 PM
Thanks.
01-31-2019 07:09 PM
As I said in the other thread where you asked the same question, it can work, but it is not a supported scenario, and you would have to do other things to make the camera control work (if that is something that you require). See my post there for further details.
Please remember to mark helpful responses and to set your question as answered if appropriate.
