05-15-2012 02:36 AM - edited 03-17-2019 11:10 PM
what is the frame rate when I using the PiP as presentation output if I have presenation codec
Solved! Go to Solution.
05-16-2012 01:52 AM
If using PIP on a CTS 3000 it should be 5FPS.
Using an External monitor your will get 30FPS.
05-15-2012 03:42 AM
Hi Ehab,
I believe the frame rate is 30 frames/second when using a Presentation codec. Sharing a presentation without Presentation codec will trasmit at 5 frames/second.
Mubashshir Akhtar
05-15-2012 03:44 AM
Hi Ehad
What system are you using?
For the 500, 1100, 1300 CTS systems, 30FPS is not supported in PIP mode.
So I assume it would be back down to 5FPS
Note The high frame rate codec does not support 30 frames/sec in presentation-in-picture (PIP) mode. An external display is recommended.
The TX series however use a software key and not a presentation codec. So 30FPS in PIP mode might be supported on the TX series.
05-16-2012 01:35 AM
Thank you,
The system is cts 3000.
if we using the PiP in CTS 3000 with presentation codec the frmae rate is 30fps or its down to 5 fps.
05-16-2012 01:52 AM
05-16-2012 02:03 AM
Thank you very much
