presentation problem on SIP calls in CUCM-VSC
onur temel
Hi All,
if you would give an advice I will be glad.
when an endpoint that is registered to CUCM-8.6.2.21900-5 makes a conference on MCU MSE 8510, the sharing presentation is shown on the media channel it does not use content channel. However same endpoint is registered to VCS-X.7.2.1 and make SIP call to MCU there is no problem, the media and presentation channels are different.
Endpoint SIP Call-->CUCM-->VCS-->MCU - media and presentation are on same channel.
Endpoint SIP Call-->VCS-->MCU - media and presentation are on different channel.
Thank you.
gubadman
Level 3
Level 3
Hi Onur,
Take a look at the following document -
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_8_9_and_X7-2.pdf
Page 46 shows you what you'll need to modify to get the BFCP working between CUCM and VCS
Guy
5 Replies 5
gubadman
Level 3
Level 3
Hi Onur,
Guy
thank you Badman,
but in our config the BFCP is enabled.
ok, can you give us more information on how the advanced zone profile for the link to CUCM is set up on VCS?
because of working hours I can not change the profile,
on an appropriate time I will try this
Thank you
Badman thank you so much,
it is working.
