11-26-2012 08:01 AM - edited 03-18-2019 12:12 AM
Hi everyone,
I have problems with the HDMI port on the EX90, not given image to connect any device (PC, tablet) to generate presentation.
The following processes were performed but the problem persists:
The problem has been presented in two different teams.
Has anyone seen this before or got some ideas to help troubleshoot it?
Oscar R
11-26-2012 11:29 AM
Hi Oscar,
We have seen various issues in TC 4.2 and it is a very old build which has been found to contain many known issues. Is there a specific reason why you're only testing on this firmware? Is there a possibility you can try on the latest and greatest TC 5.1.4 so that we can check what is the cause?
Please also let me know if the signals from the HDMI cable are HDCP. Also if possible let us know Video Input Source settings which are configured for the HDMI port. It is possible that some setting might be causing this issue.
Hope this helps.
Mubashshir Akhtar
11-29-2012 06:47 AM
Hi Mubashshir
Thanks for the info, For now it is not possible to perform the firmware upgrade (no support contract), is recommend installing the version TC4.1 to test HDMI input signals.
We are not using signals with HDCP, laptop ((Board Intel and AMD)) are connected and Apple products (iPad, iPhone).
HDMI input settings:
Name : HDMI Presentacion
Connector : HDMI
Type : PC
Quality : Sharpness
closed CameraControl
Mode : Off
CameraId : 1
closed OptimalDefinition
Profile : Normal
Threshold60fps : 1280_720
DVI input settings:
Name : DVI Presentacion
Connector : DVI
Type : PC
Quality : Sharpness
Mode : Off
CameraId : 1
Profile : Normal
Oscar R.
11-29-2012 07:40 AM
Hi Oscar,
Your HDMI settings look fine. Here are the two things you can do:
Check the Default Presentation Source set on the codec. You can do that by having a look at the following command:
*c xConfiguration Video DefaultPresentationSource: 3 (This shows that default presentation source is set to Video Input Source 3)
So this source should have the Video Input Source configured as HDMI,
Second thing you can do is upgrade to TC4.2.3 which is a minor release and does not require a release key & hence you should be able to upgrade to it.
Hope this helps.
Mubashshir Akhtar
11-29-2012 08:13 AM
Can we see status of the HDMI input ?
xstatus Video Input HDMI
*s Video Input HDMI 1 Connected: False
*s Video Input HDMI 1 SignalState: Unknown
** end
OK
And also do :
sys-con vpe0
****** Welcome to SYSTEM_VPE0 ******
Use 'quit' to end connection
OK
Connected
vpe-info all
quit
Capture your session and send over the data so we can see the status of the HDMI.
11-30-2012 08:07 AM
Thanks for the info, xConfiguration Video DefaultPresentationSource: 1 corresponds to the HDMI port:
Video xconfiguration DefaultPresentationSource
* c xConfiguration Video DefaultPresentationSource: 1
end **
xconfiguration Video Input
* c xConfiguration Video Input Source 1 Name: "HDMI Presentation"
* c xConfiguration Video Input Source 1 Connector: HDMI
* c xConfiguration Video Input Source 1 Type: PC
* c xConfiguration Video Input Source 1 CameraControl Mode: Off
* c xConfiguration Video Input Source 1 CameraControl CameraId: 1
* c xConfiguration Video Input Source 1 Quality: Sharpness
* c xConfiguration Video Input Source 1 OptimalDefinition Profile: Normal
* c xConfiguration Video Input Source 1 OptimalDefinition Threshold60fps: 1280_720
No Video Input:xstatus Video Input HDMI
** end
OK
sys-con vpe0
OK
Connected
vpe-info all
FPGA 0, max 2/4 loc/dsp0 windows
32 phases, selected phase/quality 21/832
phases 0- 7: 832 416 416 0 0 0 0 0
phases 8-15: 0 0 0 0 0 0 0 0
phases 16-23: 0 638 832 832 832 832 832 832
phases 24-31: 822 0 0 0 0 0 0 0
valid local inputs for FPGA 0:
16 (Multiplexed video link)
64 (Decoded video stream)
65 (Decoded video stream)
128 (HDMI) (0x0)
valid remote inputs for FPGA 0:
17 (Multiplexed video link)
18 (Multiplexed video link) (1920x1080)
66 (Decoded video stream)
67 (Decoded video stream) (1280x801)
81 (Menu stream) (1920x1200)
valid outputs for FPGA 0:
0 (HDMI) (1280x720@60)
64 (DSP0) (0x0@30)
65 (DSP1) (0x0@30)
80 (DSP2) (0x0)
inactive window configuration for HDMI output on FPGA 0:
1: 10000x10000@0x0 source 67 fitmode 2 border 0 active 1
inactive window configuration for DSP0 output on FPGA 0:
inactive window configuration for DSP1 output on FPGA 0:
inactive window configuration for DSP2 output on FPGA 0:
driver: vpe0 (Falcon rev F/ ), uptime: 0d 22h 32m 42s, no GHz ARM
videorx: source HDMI-1 (128) on primary input, disabled, not encrypted
videorx: local input detection: 0x0@0
videotx: display on HDMI-1: 1280x720@60 (powersaving off)
frame 1650x750, front porch 110/5, sync width 40/5, polarity +/+, dvi, digital
videotx: dsp0: 0x0@30
videotx: dsp1: 0x0@30
videotx: dsp2: 0x0@0
videodetector: lvds 4, source 18: 1920x1080p
videodetector: lvds 6, source 67: 1280x801p
videodetector: lvds 9, source 81: 1920x1200p
ad9388a: input HDMI, drive strength 2
ad9388a: HDMI signal, no DVI-D signal, unknown analog signal
ad9388a: digital has no lock, TMDS pll has lock, deglitch filter is on
ad9388a: CSC mode: auto. Detected color space: auto. Coefficient preset selected: 0
ad9389b: no hotplug, no Rx Sense, no EDID
ad9389b: no encryption
ad9389b: state: in reset, error: no error, detect count: 0, msk/irq: c0/00
ad9389b: automatic gear 0
idt5v9885b: 74250 kHz M=16 P=16 D=1 IpRz=0x33 CpCz=0x74
IRQ Total
vpe_timer : 81165
api_req : 10
system_status : 3679
core_status : 7778171
hdmi_in : 3678
hdmi_out : 0
detect_input : 0
pll_lock_lost : 1
ddrcache0 : 2
ddrcache1 : 1
detect_output : 233
local_scaler : 0
dsp0_scaler : 0
dsp1_scaler : 3
vsink_local : 5
vsink_dsp0 : 1
vsink_dsp1 : 1
vsource_local : 7776589
vsource_dsp0 : 1325
vsource_dsp1 : 0
local_composer : missing: 0 framereq: 0
dsp0_composer : missing: 0 framereq: 0
dsp1_composer : missing: 0 framereq: 0
local_crop : 0
dsp0_crop : 0
dsp1_crop : 17
dsp0_oversampler : 0
dsp1_oversampler : 0
cec_hdmi_tx : 0
cec_hdmi_rx : 0
OK
quit
With video input:
*s Video Input HDMI 1 Connected: True
*s Video Input HDMI 1 SignalState: OK
** end
OK
sys-con vpe0
OK
Connected
vpe-info all
128 (HDMI) (0x0)
67 (Decoded video stream) (640x360)
64 (DSP0) (640x368@30)
65 (DSP1) (0x0@30)
80 (DSP2) (0x0)
1: 7334x7334@1333x2608 source 16 fitmode 1 border 0 active 1
2: 2432x2432@3785x59 source 67 fitmode 0 border 0 active 1
1: 10000x10000@0x0 source 18 fitmode 0 border 0 active 1
driver: vpe0 (Falcon rev F/ ), uptime: 0d 22h 33m 54s, no GHz ARM
videotx: dsp0: 640x368@30
videodetector: lvds 6, source 67: 640x360p
IRQ Total
vpe_timer : 81238
api_req : 10
system_status : 4117
core_status : 8852094
hdmi_in : 4116
hdmi_out : 0
detect_input : 0
pll_lock_lost : 1
ddrcache0 : 2
ddrcache1 : 1
detect_output : 237
local_scaler : 0
dsp0_scaler : 0
dsp1_scaler : 3
vsink_local : 5
vsink_dsp0 : 1
vsink_dsp1 : 1
vsource_local : 8850509
vsource_dsp0 : 1325
vsource_dsp1 : 0
local_crop : 0
dsp0_crop : 0
dsp1_crop : 17
cec_hdmi_tx : 0
cec_hdmi_rx : 0
OK
quit
The display always shows the following message:
No signal
Please make sure HDMI Presentacion is connected and is sending a signal
11-30-2012 11:20 AM
If the connector (HDMI input) correct, the strange thing is that it happened in two EX90.
11-30-2012 08:57 AM
It might sound stupid but better worth checking! HDMI input ant output connectors are pretty close to each others. Are you absolutely sure cable is plugged into correct HDMI connector?
11-30-2012 02:32 PM
Thomas is right !! It is very much possible !!
I ran into some issue few months back where the customer was trying to connect the HDMI coming from the iPad but it was flickering constantly going OFF & ON. From the output you provided for both working and non-working, looks like the same flickering issue to me.
Are you transmitting the HDMI signals from an iPad or another such Tablet? If yes, then it is possible that you're seeing issues because of that. We noticed during that troubleshooting that the HDMI signals generated from the Tablet were not exactly the HDMI signals which the codec anticipates.
Plus, when you're using a PC for presentation, is that a MAC? If yes, can you try connecting a regular PC to check if the problem persists. Also make sure the screen resolution on the laptop/PC should be 1024 X 768.
Hope this helps.
Mubashshir Akhtar
12-03-2012 12:18 AM
The HDMI input does not seem to detect much :
128 (HDMI) (0x0)
This is when an HDMI detects valid input signal :
16 (Multiplexed video link) (1280x720)
128 (HDMI) (1280x720@60)
Can we connect to the vpe0 and collect some debugs?
sys-con vpe0
OK
Connected
vpe-debug -l 2 -m 3 -p -e
vpe-debug -l 2 -m 10 -p -e
wait a minute or so with your HDMI connected and then do :
vpe-debug -l 0 -m 3 -p -e
vpe-debug -l 0 -m 10 -p -e
quit
systemtools rootsettings on cisco
OK
And the login as root using ssh and password cisco and do :
cat /var/log/eventlog/vpe0.log
You should see output like this :
Dec 3 08:11:26 arm0 vpe0: 0: ad9388a_get_resolution: 1280x720@60, valid
Dec 3 08:11:27 arm0 vpe0: 0: videorx_test_signal_stability: 1280x720@60.0Hz
Dec 3 08:11:27 arm0 vpe0: 0: ad9388a_has_signal: input 0, have signal (4)
Dec 3 08:11:27 arm0 vpe0: 0: ad9388a_get_resolution: 1280x720@60, valid
Dec 3 08:11:28 arm0 vpe0: 0: videorx_test_signal_stability: 1280x720@60.0Hz
Dec 3 08:11:28 arm0 vpe0: 0: ad9388a_has_signal: input 0, have signal (4)
Dec 3 08:11:28 arm0 vpe0: 0: ad9388a_get_resolution: 1280x720@60, valid
Nothing seems to be detected on HDMI.
This is when we do detect something :
ad9388a: detected DVI-D video format 1280x720p
ad9388a: frame size 1650x750, front porch h=111 v=5, sync h=40 v=5, pix_freq=74.24 Mhz
In your case we do not get anything detected. Maybe debugs reveal some more....
12-10-2012 08:39 AM
Hi all, thanks for your help.
So far I have the problem with 2 EX90.
Is verified and tested on several PCs resolutions, also is connecting an iPad.
In making the debug, I attach the result:
Dec 10 15:12:41 arm0 vpe0: Product information
Dec 10 15:12:41 arm0 vpe0: Falcon
Dec 10 15:12:41 arm0 vpe0: Main board: F
Dec 10 15:12:41 arm0 vpe0: Running VPE0
Dec 10 15:12:41 arm0 vpe0: vpeInit: S01737A
Dec 10 15:12:41 arm0 vpe0: vpeInit: VPE0, product Falcon rev F
Dec 10 15:12:41 arm0 vpe0: vpeInit: idt5v9885b set to 74250000 Hz
Dec 10 15:12:41 arm0 vpe0: 99 MHz
Dec 10 15:12:41 arm0 vpe0: vpe_calibrate 1
Dec 10 15:12:41 arm0 vpe0: idt5v9885b: lost lock
Dec 10 15:12:41 arm0 vpe0: irq: video source dsp0: cdc fifo overflow
Dec 10 15:12:41 arm0 vpe0: dsp0 ffffffffc003
Dec 10 15:12:41 arm0 vpe0: dsp1 ffffffffffc1
Dec 10 15:12:41 arm0 vpe0: dsp0&1 ffffffffc001 (best phase 31)
Dec 10 15:12:41 arm0 vpe0: fsm_procSetup: Open Interprocessor comm devs.
Dec 10 15:12:41 arm0 vpe0: fsm_procSetup: Initialize data structures.
Dec 10 15:12:41 arm0 vpe0: fsm_procSetup: Create all FSM tasks[3].
Dec 10 15:12:41 arm0 vpe0: fsm_procSetup: Check for system synchronization.
Dec 10 15:12:41 arm0 vpe0: registerAndWaitForNotify: Sending id = SYSTEM_VPE0(20) (335544320)
Dec 10 15:12:41 arm0 vpe0: Wait for timeout, or incoming message
Dec 10 15:12:41 arm0 vpe0: registerAndWaitForNotify: Sync message received!
Dec 10 15:12:42 arm0 vpe0: fsm_procSetup: Signal tasks to run create.
Dec 10 15:12:42 arm0 vpe0: fsm_procSetup: wait for create(s) to finish
Dec 10 15:12:42 arm0 vpe0: fsm_procSetup: Signal tasks that operation can start.
Dec 10 15:12:42 arm0 vpe0: calibrated crc: OK (1 attempts)
Dec 10 15:12:42 arm0 vpe0: Starting com session
Dec 10 16:20:00 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 10 16:20:01 arm0 vpe0: 0: ad9388a_has_signal: input 0, present 4
Dec 10 16:20:01 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 10 16:20:01 arm0 vpe0: 0: ad9388a_get_analog_format: no valid format
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: 288x603@136Hz
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: new format found
Dec 10 16:20:02 arm0 vpe0: 0: ad9388a_has_signal: input 0, present 4
Dec 10 16:20:02 arm0 vpe0: 0: ad9388a_has_signal: input 0, present 2
Dec 10 16:20:02 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: 1024x1@136Hz
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: 1024x2@136Hz
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: 1024x392@136Hz
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: 1024x607@136Hz
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: format changed without signal lost, force signal lost
Dec 10 16:20:02 arm0 vpe0: 0: videorx_signal_stability_signal_lost:
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: signal found
Dec 10 16:20:02 arm0 vpe0: 0: ad9388a_get_analog_format: no valid format
Dec 10 16:20:02 arm0 vpe0: 0: videorx_test_signal_stability: 0x0@0Hz
Dec 10 16:20:03 arm0 vpe0: 0: videorx_test_signal_stability: 1024x37@140Hz
Dec 10 16:20:03 arm0 vpe0: 0: ad9388a_has_signal: input 0, present 4
For this problem which will be the cause? also updated the firmware to 4.2.3 from an endpoint but the problem persists.
Rewards,
Oscar Rebolledo
12-10-2012 11:06 AM
The codec does not seem to detect the proper input resolution.
Have not connected any input on my EX90 using HDMI yet.
Will show logging to engineering to see what they can tell me.
12-13-2012 01:24 AM
I plugged in a camera into my EX90. The are 2 HDMI connectors. Input is the one "furthest" at the back of the unit. Check the layout of the connectors in this document. Once I hooked up the camera I did some debug on VPE0 by going into tandberg shell logged in as admin and then do :
[dderidde-ex90-home:/var/log/eventlog] $ tsh
Welcome to dderidde.ex90.home
TANDBERG Codec Release TC6.1.0 PreAlpha (TEST SW, tc-6.1.0-prealpha-2086-g6d6beb6)
SW Release Date: 2012-12-12, 12:53, matchbox
OK
sys-con vpe0
OK
Connected
vpe-debug -m 3 -l 2 -p -e
OK
vpe-debug -m 10 -l 2 -p -e
OK
vpe-debug -m 9 -l 2 -p -e
OK
vpe-debug -m 15 -l 2 -p -e
OK
vpe-debug
usage:
vpe-debug [-l level -m module -p -e]
no arguments: show current debug levels
-l level:
0: debug info off
1: debug info on
2: high-volume debug info on
16 and up: module-specific levels
-m modules:
0: vpe (general vpe messages)
1: test (for internal testing)
2: api (api messages)
3: ad9388a
custom level:
16: show tmds clock status changes
4: ad9389b
5: lmh0031
6: saa7113
7: saa7128
8: ths8200
9: lvds
10: videorx
11: videotx
12: videodetector
13: composer
14: i2c
15: cec
-p : fpga prefix in log
-e : eventlog only
module 0 (vpe): level 0
module 1 (test): level 0
module 2 (api): level 0
module 3 (ad9388a): level 2
module 4 (ad9389b): level 0
module 5 (lmh0031): level 0
module 6 (saa7113): level 0
module 7 (saa7128): level 0
module 8 (ths8200): level 0
module 9 (lvds): level 2
module 10 (videorx): level 2
module 11 (videotx): level 0
module 12 (videodetector): level 0
module 13 (composer): level 0
module 14 (i2c): level 0
module 15 (cec): level 2
output: eventlog
prefix: 0:
OK
Leave the above window open and then opn 2nd window logged in as root, or alternatively, check the vpe0.log file via the WEB GUI :
http://10.60.142.199/web/logs/file/current?file=eventlog%2Fvpe0.log
Or use root to check the file /var/log/evebtlog/vpe0.log :
tail -f /var/log/eventlog/vpe0.log
(exit with
Here's is the logging I see starting with powered off camera, and then power applied to camera :
Dec 13 09:26:39 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): no signal(0)
Dec 13 09:26:39 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 13 09:26:39 arm0 vpe0: 0: get_video_std: IT format
Dec 13 09:26:39 arm0 vpe0: 0: ad9388a_detect_color_space: No AVI InfoFrame received
Dec 13 09:26:39 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:40 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:40 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): no signal(0)
Dec 13 09:26:40 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 13 09:26:40 arm0 vpe0: 0: get_video_std: IT format
Dec 13 09:26:40 arm0 vpe0: 0: ad9388a_detect_color_space: No AVI InfoFrame received
Dec 13 09:26:40 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:41 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:41 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): no signal(0)
Dec 13 09:26:41 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 13 09:26:41 arm0 vpe0: 0: get_video_std: IT format
Dec 13 09:26:41 arm0 vpe0: 0: ad9388a_detect_color_space: No AVI InfoFrame received
Dec 13 09:26:41 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:42 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:42 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:42 arm0 vpe0: 0: videorx_update_sig_present_state: report: source 128, have signal
Dec 13 09:26:42 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 13 09:26:42 arm0 vpe0: 0: videorx_test_signal_stability: signal found
Dec 13 09:26:42 arm0 vpe0: 0: ad9388a_get_analog_format: no valid format
Dec 13 09:26:42 arm0 vpe0: 0: videorx_test_signal_stability: 1920x19@2857.52Hz
Dec 13 09:26:42 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:43 arm0 vpe0: 0: videorx_test_signal_stability: new format found: 1920x1080@60.00Hz
Dec 13 09:26:43 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:43 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:43 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:43 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:43 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:43 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:43 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:43 arm0 vpe0: 0: videorx_test_signal_stability: signal stable, enable output.
Dec 13 09:26:43 arm0 vpe0: 0: ad9388a_get_format_type: format type=0x6 status=0x0
Dec 13 09:26:44 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:44 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:44 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:44 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:44 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:44 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:44 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:45 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:45 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:45 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:45 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:45 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:45 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:45 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:46 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:46 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:46 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:46 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:46 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:46 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:46 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:47 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:47 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:47 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:47 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:47 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:47 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:47 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:48 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:48 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:48 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:48 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:48 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:48 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:49 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:49 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:49 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:49 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:49 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:49 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:49 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:50 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:50 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:50 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:50 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:50 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:50 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:50 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:51 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:51 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:51 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:51 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:51 arm0 vpe0: 0: ad9388a_get_resolution: 0x0@0, invalid
Dec 13 09:26:51 arm0 vpe0: 0: videorx_test_signal_stability: re-enable output: 1920x1080@60.00Hz (1)
Dec 13 09:26:52 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:52 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:52 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:52 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:52 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:52 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:52 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:53 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:53 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:53 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:53 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:53 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:53 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:53 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:54 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:54 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:54 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:54 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:54 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:54 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:55 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:55 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:55 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:55 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:55 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:55 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:55 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:56 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:56 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:56 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:56 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:56 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:56 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:56 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:57 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:57 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:57 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:57 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:57 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:57 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:57 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:58 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:58 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:58 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:58 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:58 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:58 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:58 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:26:59 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:26:59 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:26:59 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:26:59 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:26:59 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:26:59 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:26:59 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:00 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:00 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:27:00 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:27:00 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:27:00 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:27:01 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:27:01 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:01 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:01 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:27:01 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:27:01 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:27:01 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:27:02 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:27:02 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:02 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:02 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:27:02 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:27:02 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:27:02 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:27:03 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:27:03 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:03 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:03 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:27:03 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:27:03 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:27:03 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:27:04 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:27:04 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:04 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:04 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:27:04 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:27:04 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:27:04 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:27:05 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:27:05 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:05 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:05 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Dec 13 09:27:05 arm0 vpe0: 0: videorx_test_signal_stability: 1920x1080@60.00Hz
Dec 13 09:27:05 arm0 vpe0: 0: videorx_ad9388a_has_signal: input: 128
Dec 13 09:27:05 arm0 vpe0: 0: ad9388a_has_signal: HDMI input(0): have signal(4)
Dec 13 09:27:06 arm0 vpe0: 0: ad9388a_get_resolution: 1920x1080@60, valid
Dec 13 09:27:06 arm0 vpe0: 0: get_video_std: CE HD format
Dec 13 09:27:06 arm0 vpe0: 0: ad9388a_detect_color_space: RGB full
Dec 13 09:27:06 arm0 vpe0: 0: ad9388a_set_color_space: RGB full
Could you please try with a specific resolution and specific device so we have a baseline what you are connecting and I will try to do the same.
Danny.
12-24-2012 08:26 AM
The tests were performed with the same resolution settings in the EX90 and the PC.
You can fix the problem by updating the firmware (TC5.1.5) because the team have version 4.2.3.
PROBLEM MAY BE PHYSICAL IN PORT HDMI.
Rewards
Oscar Rebolledo
