I’m currently running a sx80 VTC implementation and using the Cisco Collaborative Endpoint Software API version ce9.5.1 be5deaf82e6. I’m able to hook up my labtop to the VTC and start a presentation but I am unable minimize. The command that I’ve been using is “xCommand Video PresentationView Set View: Minimized”. I’ve entered the command through ssh and the VTC web GUI in the developer API section. In both those cases they’ve apparently succeeded but does not visibility change the monitor being presented on. I’ve looked at the system logging and it says that the commands were executed successfully. I’d like to change the position of the presentation using “xCommand Video PresentationPIP Set” but assume this isn’t working because I can’t minimize in the first place.
Any suggestions would be appreciated.
