12-29-2015 04:50 AM - edited 03-18-2019 05:21 AM
I'm having trouble with a VCS equipment to achieve formats it, when I use the command "factory reset" it shows me an error with serial number and release key as you can see in the attached image.
In addition to the above problem, it does not allow access to console with administrator user interface only with root, and also does not have to log in via browser (white screen).
Has anyone had a similar experience, or have any information that may help to be able to format the equipment to see if return to normal operation?
Solved! Go to Solution.
12-29-2015 07:01 PM
When logged in as root you can manually enter the release key in to the system.
Use the following command:
echo 1234567890123456 > /tandberg/etc/rk
where 1234567890123456 is your 16 digit release key
Following that, reboot the VCS.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-29-2015 09:28 AM
Was anything changed on the VCS before this started happening?
I'd suggest you contact TAC, from what you say the VCS can't be accessed and obviously a factory reset is failing to resolve any of the issues.
12-29-2015 07:01 PM
Wayne
