Highlighted
dal Participant
Participant
Problems with QoS between 2950 and 3550 with use of Native VLAN
Hi!
I try to set up QoS between a C2950 and a C3550, I have provided a drawing that might help understanding the setup.
As I understand it, since I only have the SMI image on the C2950 I have to run a 802.1Q trunk over the leased 2Mb line to get QoS to work. And I DO get it to work, or at least it seems so to me.
What I'm trying to setup QoS on is between a Nortel Succession Media Server and a Nortel i2004 IP Phone.
And when I sniff the port that the Succession Media Server is connected to, I get this output:
*BEGIN*
*** TO IP Phone ***
IP version: 0x04 (4)
Header length: 0x05 (5) - 20 bytes
Type of service: 0xB8 (184)
Precedence: 101 - CRITIC/ECP
Delay: 1 - Low delay
Throughput: 1 - High throughput
Reliability: 0 - Normal reliability
Total length: 0x00C8 (200)
Flags
Don't fragment bit: 0 - May fragment
More fragments bit: 0 - Last fragment
Fragment offset: 0x0000 (0)
Time to live: 0x40 (64)
Protocol: 0x11 (17) - UDP
Checksum: 0x69EC (27116) - correct
Source IP: 10.40.2.10
Destination IP: 10.10.153.100
IP Options: None
UDP
Source port: 5216
Destination port: 5200
Length: 0x00B4 (180)
Checksum: 0x5C02 (23554) - correct
*** FROM IP Phone ***
Flags
Time to live: 0x7F (127)
Checksum: 0x0848 (2120) - correct
Source IP: 10.10.153.100
Destination IP: 10.40.2.10
IP Options: None
UDP
Source port: 5200
Destination port: 5216
Checksum: 0x5631 (22065) - correct
*END*
But, then to the problem:
Since the modems I use have ip adresses in them I want to monitor them and be able to change settings in them.
But to connect to units within the trunk, I have to set the native vlan to VLAN 144, which provides the ip adresses I use for the modems, in both ends of the trunk.
But if I do that the tagging of the packets from the IP Phone disappears!
Here's an output after native VLAN is applied:
*BEGIN*
*** TO IP Phone ***
Flags
Checksum: 0xEAD4 (60116) - correct
IP Options: None
UDP
Source port: 5240
Type of service: 0x00 (0)
Precedence: 000 - Routine
Delay: 0 - Normal delay
Throughput: 0 - Normal throughput
Flags
Checksum: 0x01A1 (417) - correct
IP Options: None
UDP
Source port: 5200
Destination port: 5240
Checksum: 0x31CA (12746) - correct
*END*
See, there is noe QoS tagging from the IP Phone anymore.
If I set no switchport trunk native vlan 144 in both ends the tagging is back.
Any ideas? Is this a bug, or just some command I don't know about?
Please take a look at the picture to get a more understandable view of the setup.
Thanks!
1 REPLY 1
Highlighted
Beginner
Re: Problems with QoS between 2950 and 3550 with use of Native V
Well, native VLANs are by definition untagged so there´s nothing wrong with that as far as you are getting the expected results. By the other way I think you should include VLAN 402 on your allowed vlan range on Catalyst 3550's FastEth0/45 trunk port, otherwise this VLAN will be completly isolated from the rest of the network.
