QoS for VOIP/Video help
JG1978
We run video and VOIP in our network but I am unsure if our QoS is working correctly.
I have done some research but when I show our service policy output, we are only getting matches on "0" and "6"
.....from what I read on wiki:
https://en.wikipedia.org/wiki/Type_of_service
IP Precedence "6" should have to match the markings of CS6 or 48 but I do not see those on our policy map.........what is causing everything to be either class 0 or 6 in my config?
Here is our class map/Policy config:
class-map match-any P1
 match ip precedence 5
 match ip dscp ef
 match protocol rtp audio
class-map match-any P2
 match ip precedence 4
 match protocol h323
 match protocol rtp video
 match protocol rtcp
 match protocol rtsp
 match ip dscp cs3
class-map match-any P3
match ip precedence 2 3
match protocol sip
policy-map VOIP_VIDEO
 class P1
  priority percent 40
 class P2
  bandwidth percent 20
 class P3
class class-default
 fair-queue
 random-detect
policy-map QoS_Parent
 class class-default
  shape average 16000000
 service-policy VOIP_VIDEO
Wayne DeNardi
Are all your network devices set to trust any QoS markings and pass them on, if not, they'll re-mark everything to the default (0) which is where all your traffic is.
Have a good read through the Enterprise QoS Solution Reference Network Design Guide for some configuration examples of how you should consider configuring your environment.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
