Community Helping Community
528
Beginner
Quality issues with CUCM 8.6
Hello, I am experiencing quality issues on my TP systems (packet lost, sessions going down, unregistered endpoints...) since I upgraded to 8.6.2.20000-2.
Is there any known issue with this version?
Manuel
Everyone's tags (5)
4 REPLIES 4
Hi Manuel
What version did you have before? Are you using same platform?
Did you verify NIC settings, duplex, ect?
Rafal
Beginner
I was on a 7.1.5 before running on a MCS.
Now we have moved to UCS.
I have check the NIC settings and everything looks fine.
Manuel
Hi Manuel,
Though this doesn't match all of your symptoms, this change comes to mind and is worth verifying: DSCP for TelePresence Calls introduced with CUCM 8.0 and CTS 1.7.4.
Paula
Highlighted
Enthusiast
Hi Manuel, FYI, that version of CUCM isn't supported in a TelePresence environment.  You might want to upgrade to CUCM 8.6(2a)SU2.
Check out the matrix:
http://www.cisco.com/en/US/docs/telepresence/cts_admin/1_8/compatibility/cts_compatibility_master.html
Thanks,Jeff
Content for Community-Ad
FusionCharts will render here
