3694
abioST
Beginner
Register Webex Room 55 Dual in CUCM v12.0 - Issue StatusFailed: 485 Ambiguous / Device type mismatch
Hello all,
I deployed CUCM v12.0.1.1 with room kit device pack and now I have to register a Webex Room 55 Dual with collaboration endpoint 9.5.1 and select Cisco Spark Room 55 product type with SIP protocol for that requirement. But  i have an issue with unknown registration and none ipv4 address. Then, I checked Roomkit 55D status and show ERROR: SIP Registration too.
The device is showing SIP Registration failed.
I have created a local user and associeted it with the device also but still not registered.
There are some logs to find in status logs
*s SIP Proxy 1 Address: "10.X.X.X"
*s SIP Proxy 1 Status: Active
*s SIP Registration 1 Reason: "485 Ambiguous / Device type mismatch"
*s SIP Registration 1 Status: Failed
*s SIP Registration 1 URI: "user@domain.net"
Best regards,
AST
1 ACCEPTED SOLUTION
@abioST wrote:
I'm searching the latest device pack release in January
The January one isn't the latest - there is a February version:
https://software.cisco.com/download/home/286313357/type/282074299/release/12.0(1.22033)
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
11 REPLIES 11
@Syed
Participant
As far as my knowledge is concerned webex board can only be registered with Cisco cloud, you may double check on this.
You can register in Cisco cloud and on-premise mode witch CUCM.
Nick Halbert-Lillyman
Collaborator
You shouldn't need to configure a user for it. Just add the MAC address to CUCM, then change "provisioning mode" to "CUCM" on the endpoint and point it to the CUCM server/s.
If you've only just installed the device pack you *may* need to restart Tomcat and/or Callmanager services.
Hi Nick,
I 've checked those options in CUCM and endpoint,but it is configure already. About the Tomcat service, I restart it after register the endpoint. Thanks for your support.
Wayne DeNardi
VIP Advisor
As @Nick Halbert-Lillyman said, after installing a new device pack on CUCM version 11.5(1) or later, you need to make sure you have restarted your Cisco Tomcat service on all nodes, restarted the Cisco TFTP on all servers where the service is running and restarted Cisco CallManager on the Publisher.
Wayne
Tianjun Zhou
Beginner
You can install the latest device pack and select product type Room 55 Dual, not Room 55
Tianjun is correct - this is your problem. The Room 55 Dual is a newer endpoint than the single, and is a different device type - your error clearly indicates that's your problem. You will need to upgrade your device pack and recreate this endpoint (you can't change the device type after you've added the device).
HI PJMack, I appreciate your advice. I've been surfing on the web and find the latest device pack release in January. I've checked the model name but i can't find Cisco Webex Room 55 Dual. Those models was attached with a bug ID CSCvm36477 but not for Cisco Webex Room 55 Dual.
Can you share the link with the device package for Cisco Webex Room 55 Dual if you have it, please?
Cisco TelePresence DX80
Cisco Webex Room Kit
Cisco Webex Room 55
Cisco Webex Room KitPlus
Cisco Webex Room 70
Single
Cisco Webex Room 70 Dual
Best regards,
Abio ST
Thanks for your help @Tianjun Zhou. I'm searching the latest device pack release in January but i can't find spark room 55 dual in link. Maybe can i use one of those options for some compatibility device or its mandatory to use spark room 55 dual device type?
https://www.cisco.com/web/software/282074299/145129/cmterm-devicepack12.0.1.23033-1_Release_Notes.pdf
Cisco TelePresence DX80 CSCvm36477
Cisco Webex Room 55
Cisco Webex Room 70
Single
Abio ST
Wayne
Thank you for your assistant @Wayne DeNardi. When i checked released notes it was published January 30 and does not indicate the device model cisco webex room 55 dual type.
Also I checked the matrix compatibility, but the last updated was February 5. There's no devices with collaboration endpoint 9.5
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix.html
I think Cisco has not yet updated its matrix with the latest versions of CE.
Create
Recognize Your Peers
Content for Community-Ad
