AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
875
Remote Acces to CUCM for telepresence device -
In my deployment of remote access I have jabber access (that working fine), and remote access for telepresence devices (that not working). I've tried to register EX90, SX10, Sx20 but without success. From Expressway C logs , I found some repeating error.
edgeconfigprovisioning: Level="INFO" Detail="Failed to find username or token in request."HTTPMSG:
|GET /dHJpdGVjaC5wbA/get_edge_config/ HTTP/1.1
Via: https/1.1 vcs[B020A31A] (ATS), http/1.1 vcs[C0A80103] (ATS)
X-Forwarded-For: 83.142.193.234, 127.0.0.1
Accept: text/xml
User-Agent: Cisco/TC
Accept-Charset: ISO-8859-1,utf-8
Host: 127.0.0.1:22110
Content-Type: application/x-www-form-urlencoded
Software on devices is TC7.1.4
Any idea wha tcan be wrong ??
Tomasz
17 REPLIES 17
Advocate
What username are you using
What username are you using for this device?
Please rate useful posts.
CUCM user that have that
CUCM user that have that device assigned.
I atteched screenshot from my
I atteched screenshot from my SX20 web interface
Beginner
Hi Tomasz,Did you find a way
Hi Tomasz,
Did you find a way to fix this? I have exactly the same situation on my site. Jabber clients works fine with MRA but for SX20 on Expressway-C I received this log:
HTTPMSG:
|GET /c2FnYS5ycw/get_edge_config/ HTTP/1.1
Via: https/1.1 vcs[C1CB1A15] (ATS), http/1.1 vcs[0A01C815] (ATS)
X-Forwarded-For: 94.189.165.11, 127.0.0.1
Accept: text/xml
Cookie: JSESSIONIDSSO=99ACC65F5D63301FCA43C88A5E80969D
Dalibor
Contributor
i was able to sort out but i
i was able to sort out but i think it was on the firewall end...im saying i think cause i cant remember.
what i do remember (and i can try to help since i have access to everything) is that my firewall rules were screwed up and i sorted and i also uploaded the CA onto my SX10 and from there everything was fine and i was able to register fine......BTW the SX10 quality is brilliant :)
thanks and i can help however i am still learning as well
Beginner
Just info. I succeed to solve
Just info. I succeed to solve the problem. Problem was with sertificates on Exp-C and CUCM. SX20 client on CUCM was configured with TLS, when I change it to TCP everything works fine.
I hope this can help
Contributor
Hi there, were you able to
Hi there,
were you able to find the answer? im having trouble with an SX10 as well with the same error.
appreciate any feedback
thanks
I have the same error with an
I have the same error with an EX-60 running TC7.2.0 and VCS 8.2.1 with UCM 9.1.2.
Advocate
Will you be able to upload
Will you be able to upload logs here? Diagnostic logs with developer.xcp and developer.edgeconfigprovisioning set to detail. If not, you will have to open a TAC case.
Highlighted
Here you go.
Here you go.
Advocate
Are you trying to register it
Are you trying to register it to UCM or VCS? I see that you are using VCS and not Expressways. It looks like the you have ineteng.com as the SIP domain in VCS, have you configured the username/password for the EX90 on this VCS, similar to how you have Movi accounts setup.
UCM via MRA.  the user name
UCM via MRA.  the user name is in VCS via TMS.  we were using this for Movi as well before MRA.  The EX-60 MAC is 00506005B3A8.  I also put a start and stop marker in the log.
Start = EX-60 Provisioning Start
Stop = EX-60 Provisioning Stop
Advocate
The username shouldn't have
The username shouldn't have to be in VCS. When you setup your SIP domain, you specify if that domain needs to have registrations on VCS or CUCM and in your case its set for VCS. Do you have MRA working at all? Can you send me a screenshot of the SIP domains page from VCSC?
I am using it for both VCS
I am using it for both VCS and MRA registrations.  I have Jabber clients connecting with no problem (Movi and UCM Jabber).  I can see in the logs where the VCS sends the UDS request to UCM for my login.
2014-09-29T14:58:55-04:00 VCSC traffic_server[22765]: UTCTime="2014-09-29 18:58:55,745" Module="network.http.trafficserver" Level="DEBUG": Detail="Sending Request" Txn-id="178" Dst-ip="172.22.5.80" Dst-port="8443"
HTTPMSG:
|GET /cucm-uds/user/mjefferson/device/b802ff7d-a97d-5b95-856b-b705dbc5d0d6 HTTP/1.1
Host: 172.22.5.80:8443
Cookie: JSESSIONIDSSO=FAD933F56B9FA1E93571E3BC95BACF3C; X-Auth=185e6740-7fd4-4664-aade-933645a8bcd8
Accept: */*
X-Forwarded-For: 108.217.223.24, 127.0.0.1
Via: https/1.1 vcs[D836D1F5] (ATS), http/1.1 vcs[AC160532] (ATS)
Content for Community-Ad
August's Community Spotlight Awards
