08-26-2016 06:30 AM - edited 03-18-2019 06:19 AM
Hi Guys,
I am fairly new to cisco telepresence and trying to build a BoM for a customer. I have identified and chosen to use Cisco TelePresence MX300 55 Gen 2 (CTS-MX300-K9).
I need to confirm the following
1. Do I need a CUCM at the back-end?
2. Do I need a gateway between the CUCM and the internet to be able to hold conference with external users and partners
I would really appreciate all the help I can get so I dont miss out any requirement/component
Richard
Solved! Go to Solution.
08-26-2016 03:03 PM
You can deploy it using either CUCM, VCS, or even standalone, although standalone isn't an officially supported deployment.
If you use CUCM, an Expressway-C/E allows for B2B calling with external endpoints.
08-26-2016 03:03 PM
