Community Helping Community
226
Participant
ROOM 70 DUAL DISPLAY ISSUE
Running CISCO WEBEX Room 70 Dual G2 with Ce9.8.x firmware.
Problem is dual display input.
The Computer input one and the display is mirrored.  Is there a setting to extend display between the two monitors on the 70???
Want to show a video on one screen and content on another screen ...
Chet Cronin
801-815-3539(USA)
801-815-3539 (AFG)
2 REPLIES 2
Re: ROOM 70 DUAL DISPLAY ISSUE
The default behavior when *not* in a call is to show content sharing on both displays. To see local video you would need to toggle on Self View from the Touch 10 and then maximize it to fill a display.
The default view when in a call is exactly what you want: video on the primary display and shared content on the other. If that is not happening then it’s possible your call control platform or far-end endpoint are not using BFCP, instead sending content in the main video channel.
VIP Advisor
As you are only connecting a single computer via a single cable, there is only one video signal, so it won't be "extended" to both screens as you would get if you connected two monitors separately.
If you connected two content cables to your laptop/pc/etc to both the content inputs, then you could "extend" your device's display to the two different screens.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Content for Community-Ad
FusionCharts will render here
