Room Kit direct call without registration
Hi!
Can Room Kit/Plus make direct calls withour registration?
As I understand it works with CE9. So it means that it can make direct call via SIP/H.323  without any registration.
Am i right?
Be ready
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Contributor
Re: Room Kit direct call without registration
Yes, that is correct. Both RKs can function independent of any video infrastructure; or they can be registered to CUCM, VCS or Spark Cloud.
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
20 REPLIES 20
Highlighted
Contributor
Thank you,
Justin Ferello
Highlighted
Thank you!
Be ready
Highlighted
Beginner
Dear Sir If Possible to direct Call Connect CIsco webex roomkit to sx20??
@Valeriy Tarazanov wrote:
Thank you!
Highlighted
Hi Justin,
Do you know if a Cisco  Spark Room Kit can call through direct IP dialling to a 3rd party VC endpoint?
Highlighted
Forgot to mention that the CSR Kit is registered in the Spark cloud.
Highlighted
VIP Advisor
If your SRK is registered to the Spark Cloud, then you can dial a SIP URI.  If you've only been given an IP address, try sticking something and an @ in front of the IP, ie endpoint@ipaddress.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Highlighted
Thanks.
Tried that, with no success. Any other ideas?
Highlighted
VIP Advisor
If that's the case, then the other system is likely a H.323 device, not SIP, so you'll need to have something in between them that can interwork the protocols.
Wayne
Highlighted
That is correct. But in the documentation you specify that csr kit supports
h323. No mention to the need of anything in between.
Highlighted
VIP Advisor
The SRK endpoint does support H.323 if used as a Standalone unit (as per the original poster's query), or if registered to a Call Control Platform that supports H.323 (ie Cisco VCS), or, with something that can interwork between SIP and H.323 if it is registered to a SIP only Call Control Platform (CUCM / Spark Cloud / etc).
Wayne
Highlighted
Can I convert it to stand alone? Do I need aditional licensing?
Highlighted
Endpoints registered to Spark purchased under MSRP pricing can't be converted to standalone endpoints, they only support bring registered to Spark. Endpoints purchased under GPL pricing can be registered to on-premise call control and/or operate standalone.
Highlighted
Thanks for the info, Patrick.
Highlighted
Contributor
Interesting, how do they prevent this via the software? Could you just use TFTP to load the regular PKG on the unit?
Thank you,
Justin Ferello
