08-13-2020 08:24 AM
Hi..
With the roomkit mini you can use the device as a pass thru camera if you connect the usbc port to a usb port on a computer.
With the usb lead max lenghths being approx 4/5 m. Do you know if its feasible to use a usb over cat 5 extender such as the icron ranger 2211 ?
thanks for any replies
02-05-2021 12:32 PM
I'm also troubleshooting a deployment that utilizes Crestron USB-EXT-2 extenders. The Crestron documentation stated some devices may not support USB hubs, which is how the extender kit appears to the devices https://www.crestron.com/getmedia/94308534-ef1d-43bd-b006-bbc7ffc06bff/mg_qs_usb-ext-2-local_usb-ext-2-remote
I wonder if there is a specific USB extension system known to work with Room Kit Mini?
02-09-2021 08:43 AM
This was resolved by switching the local and remote sides of the USB extenders
09-07-2021 10:47 AM
So I'm running into a similar issue. I am using a USB extender for this. My issue is when I unplug the USB cable from my laptop, the home screen of the USB Room Kit still shows as if it's plugged in. Has anyone else had this issue? If not, which USB extender worked for you?
