05-25-2021 11:11 AM
hi
on the Room Kit Plus, are the ethernet connections (LAN, Camera Control, Touch 10) all linked, as in same subnet and non blocking switch inside codec?
Need to have the quad camera and a P60 connected so will use a switch for the extra ports needed, but client would like more than one location for the Touch 10 to be located, so would like to use the same switch as the camera control for extra (POE) Touch10.
This cant be on client LAN and needs to be direct connection to codec but via a switch.
Have seen examples showing this for extra camera control, but wondering if i can use the same switch for Touch10 direct pairing.
thank
Solved! Go to Solution.
05-26-2021 02:10 PM
The LAN port is not connected to the other two, that is to connect to your LAN. Traffic does not route between the LAN port and the other two.
The camera port and Touch 10 port are essentially the same except for one thing: the Touch port has POE to power the device. You can connect your second Touch to one of your LAN/network POE port, but when pairing over the network you have to provide credentials. My recommendation would be to use a small POE switch, in that case I'm quite sure you can connect your extra camera and Touch/Navigator to it and they'll pair automatically no problem.
Hope this helps!
05-25-2021 12:15 PM - edited 05-25-2021 12:24 PM
Network Ethernet and Camera Control Ports have separate functions. I don't think Camera Control port ever gets any IP Address and can be a part of LAN.
As per my knowledge and as per installation guide, at a time you can connect either Quad Camera or Precision 60 to Room Kit Plus. You can not connect both to Room Kit Plus. It has only one Camera Input HDMI Port.
If you need both Cameras then you need to upgrade to Room Kit Pro. Please check installation guide for both devices below:
05-25-2021 12:34 PM
05-25-2021 01:40 PM
You are right. The administrator guide has more details.
Please check page 47 in same document. It has details about how you can connect Touch 10 to same switch using Network Ethernet port. In the past, I have used Touch 10 over LAN but with other video endpoint.
05-25-2021 09:44 PM
I have have done touch 10 integration by connecting to a switch, but the touch and CS kit was in same vlan .To pair it i have to provide the credentials, that's what i remember .
If the switch you configured to connect the camera control , and CS kit are in same valn connect your Touch and see if its able to find the CSKIT. i hope it should work, but this can only be confirmed by a POC. Because camera control Using a switch in between is not a common scenario. For two cameras i normally suggest to go with CS kit pro.
05-26-2021 02:10 PM
Hope this helps!
