room kit plus third 3rd party microphone
time
Beginner
Beginner
I'm looking to install a roomkit plus, using a third party DSP.
I cannot find and audio specifications for the "mic" inputs on the codec plus. Some people on the forums mention that only cisco mics are supported, other people say all third party mics are  supported.
Can I please be pointed to some official documentation showing which is true?
5 REPLIES 5
PJMack
Rising star
Rising star
Cisco's install guide states that Cisco mics are "recommended", but nowhere do they say they are required. Cisco does support installations with third party mic's - I have dozens of Cisco systems in my company (including new Dual 70's) with external DSP's and third party microphones. One note - the Room Kit/Plus does not give you the ability to set the mic input to line level, only mic, so you have to plan for that. Easily doable once you know that information.
Wayne DeNardi
VIP Advisor VIP Advisor
VIP Advisor
Similar to @PJMack, in the majority of our installations we also use external DSP for both the audio in, as well as the audio out, of the endpoints.  The issue about using external mics on the unit is usually around Phantom power, but if you are powering the microphone from the DSP, then this is not an issue.
You will still need to feed the output from the DSP in to the endpoint as a mic level feed, and with a 4-pole cable.
See the "Connect a third party microphone to a Cisco SX20" article which describes some ways to achieve this (and to directly connect a mic that needs phantom power).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Third party is supported. However not all microphones would work straight away. It is a 4 conductor 3.5mm connector. The 4 conductor is necessary and using a standard 3 conductor 3.5mm like a headphone jack would not work and sounds horrible. You must leave the R2 connection open and not short it to ground or other pins.
See this thread regarding Pin outs: https://community.cisco.com/t5/telepresence-and-video/sx20-pinout-description/td-p/2768025
Joe Hughes
For integration with Shure see the document:  "Shure Microflex Ecosystem and Webex devices"
https://www.webex.com/content/dam/wbx/us/setup-guide/D1547901_shure_webex_setup_guide_v1.pdf
This document refers to both the Webex Room Kit Plus and the Codec Plus based devices.  The Room Kit Plus is a Codec Plus based device.  For the 3.5 mm connector, you will need the *Shure VCC3 Video Conference Cable Kit* then rest of the Shure Microflex system.   According to the documentation the mute capability can be used with the Shure microphones, which you would not get with most other 3rd party microphones.
VatanRohilla104
Beginner
Beginner
