rtsp and rtp on ip camera 6400
giulap
I hace camera IPC-6400. I must use the protocol rtsp for connected on the nvr third party. Is there somebody that know the URL RTSP? Thanks
Wayne DeNardi
Being an ONVIF camera, you may be able to find out the RTSP stream URL by using ONVIF Device Manager.  I've used this a couple of times for other Manufacturer's cameras, but haven't specifically tried it on the Cisco 6400.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
giulap
I use the software "Onvif Device Test Tool", but when i test the camera the response is " Sender not authorized". The user and password is correct. " <SOAP-ENV:Body>
<SOAP-ENV:Fault>
<SOAP-ENV:Code>
<SOAP-ENV:Value>env:Sender</SOAP-ENV:Value>
<SOAP-ENV:Subcode>
<SOAP-ENV:Value>ter:NotAuthorized</SOAP-ENV:Value>
</SOAP-ENV:Subcode>
</SOAP-ENV:Code>
<SOAP-ENV:Reason>
<SOAP-ENV:Text xml:lang="en">Sender not authorized</SOAP-ENV:Text>
</SOAP-ENV:Reason>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>"
I enabled "Onvif" and "disable session id"
Did you enter the right username and password in to the tool?
Wayne
