SF-300 Voice V-LAN
adeeldar80
HI,
I want to create two voice V-LAN on Cisco SF-300 to cater different VOIP (Cisco and Yealink) both has difference DHCP pool.
and SVI created on 3750. and interconnected with trunk mode.
Problem: I can not create 2nd Voice v-lan, on one Voice  vlan it work fine.
Best Regards,
Adeel Dar
Jaime Valencia
This is the Video Over IP community, you might want to move this to a relevant area.
java
if this helps, please rate
