ā08-02-2017 06:06 AM - edited ā03-18-2019 01:22 PM
I have CUCM 10.5 in HQ. remote site having Cisco 2811 router connected over IPSec VPN.
During outbound dialing, no incoming voice after every minutes or less but call remains connected.
please advise.
voice service voip
no supplementary-service sip handle-replaces
sip
bind control source-interface FastEthernet0/1
bind media source-interface FastEthernet0/1
voice class custom-cptone FXO-CUSTOM
dualtone disconnect
frequency 425
cadence 375 375
voice translation-rule 1
rule 1 /^.*/ /9&/
voice translation-profile from-PSTN
translate calling 1
ip ssh version 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key <PASSWORD> address <REMOTE PUBLIC IP>
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map HAWK 1 ipsec-isakmp
set peer <REMOTE PUBLIC IP>
set transform-set myset
match address 105
interface FastEthernet0/0
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
hold-queue 100 out
ip address 192.168.100.252 255.255.255.0
ip nat inside
duplex auto
speed auto
h323-gateway voip bind srcaddr 192.168.100.252
interface Dialer1
ip address negotiated
ip access-group OUTSIDE in
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username <USERNAME>password <PASSWORD>
crypto map HAWK
ip default-gateway <GATEWAY IP>
ip forward-protocol nd
ip http server
ip http secure-server
ip dns server
ip nat inside source list 110 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended OUTSIDE
deny tcp any any eq 5060
deny udp any any eq 5060
permit ip any any
access-list 105 permit ip 192.168.100.0 0.0.0.255 10.172.192.0 0.0.0.255
access-list 110 deny ip 192.168.100.0 0.0.0.255 10.172.192.0 0.0.0.255
access-list 110 permit ip 192.168.100.0 0.0.0.255 any
access-list 110 permit ip any any
voice-port 0/0/0
input gain 14
output attenuation -6
cptone PK
timeouts call-disconnect 0
timeouts ringing 30
timeouts wait-release 1
connection plar opx 110
shutdown
caller-id enable
voice-port 0/0/1
input gain 14
cptone PK
timeouts ringing 30
shutdown
caller-id enable
voice-port 0/0/2
input gain 14
cptone PK
timeouts ringing 30
connection plar opx 115
caller-id enable
voice-port 0/0/3
input gain 14
cptone PK
timeouts ringing 30
caller-id enable
mgcp profile default
dial-peer voice 11 pots
destination-pattern .T
port 0/0/0
dial-peer voice 12 pots
port 0/0/1
dial-peer voice 13 pots
port 0/0/2
dial-peer voice 14 pots
port 0/0/3
dial-peer voice 100 voip
destination-pattern 110
session protocol sipv2
session target ipv4:10.172.192.21
incoming called-number .
voice-class sip bind control source-interface FastEthernet0/1
voice-class sip bind media source-interface FastEthernet0/1
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
gateway
media-inactivity-criteria rtp
timer media-inactive 10
timer receive-rtp 1200
ā08-04-2017 05:27 AM
Make sure there are no routing issues and all the required ports related to RTP are opened on the FW.
Deepak
ā08-05-2017 07:17 AM
You may have one or both of these 2 problems : network (routing) and/or firewall (ports) issue(s)
While on call, type "show voip rtp connection" on the 2811.
You should see an IP address (the IP address of the IP phone should if not using an MTP), if IP phones are in a different VLAN than 10.172.192.0/24, also make sure to exempt them from NAT.
Make sure that 192.168.100.252 (since you're binding everything to Fa0/1) is able to ping the IP address of the IP phone. If not, means you have a routing problem. Solve that.
Then, try again, if the problem persists, double check your firewall rules/access-lists.
ā08-22-2017 03:31 AM
