09-02-2011 05:04 AM - edited 03-17-2019 10:28 PM
Hello, all!
Which OID's does Cisco-Tandberg Edge 95MXP support?
And can this codec generate snmp-traps?
Thanks for any help.
09-05-2011 01:06 PM
Hi Maksim , I am from TAC and i wanted to post a reply for the service request attached to this Discussion The OID that Tandberg supports is 1.3.6.1.4.1.5596. Every Tandberg endpoint can act as an SNMP agent and can generate traps. All you need to do is configure a host in Control Panel >Network >LAN Settings >SNMP SETTINGS HOST Identifies the IP-address of the SNMP Manager.The system's SNMP Agent (in the codec) responds to requests from SNMP Managers (a PC program etc.). SNMP Traps are generated by the SNMP Agent to inform the SNMP Manager about important events. The TANDBERG Enterprise MIB currently holds a lot of information about the status of the Codec. The information are divided into: · status · logging · services · system In addition the following enterprise traps are defind. · callModeChange · genericError · lowBattery · downSpeeding · startUpgrade · finishedUpgrade · dispbox · connect · encryption · gatekeeperRegFailure · gatekeeperRegSuccess I am attaching a document to the post that explains the SNMP feautres of Tandberg endpoints http://www.tandberg.com/collateral/white_papers/whitepaper_SNMP-Technical_Manual.pdf
09-05-2011 02:24 PM
Hi Maksim,
Forgot to mention this document is a little dated and explains the details with B-series and E-series of software but its completely valid on current range of MXP systems running F-series of software.
