Walkthrough Wednesdays
1166
alwin.emanuel
Beginner
Spark Room 55 Loses H323 Settings
Hi all,
I'm having an issue with this system with regard to keeping H323 settings. Originally the system was registering to CUCM but on every restart, the system loses the H323 settings and shows a Status of Inactive. From what I can tell, it enables SIP by default (we don't use that anymore) and turns off H323. Does that just mean it's going to factory? I can manually configure it for H323 and it will register, but only for that current session. What should I be looking for? I've played around with Provisioning.
Currently running software version ce 9.4.0 ...4505.
1 ACCEPTED SOLUTION
Wayne DeNardi
VIP Advisor
It sounds very much like the device is still being provisioned by your CUCM.  Have you removed the device from CUCM so that it doesn't see the endpoint and then re-configure it?  Do you have anything else on site that may be putting a configuration template on the device (Cisco Prime, Cisco TMS, etc)?
The other option is that someone may have turned the persistency mode on on the endpoint, so the endpoint reverts back to a defined set of settings on a restart
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
11 REPLIES 11
Anurag Srivastava
Hello Alwin,
If you are provisioning through CUCM you will not be able to use the H323 settings.
Its mentioned in release notes-
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce9/release-notes/ce-software-release-notes-ce9.pdf
So if you wanted to use both H323 and SIP, please turn off the provisioning mode and configure the SIP proxy as CUCM and it will not change the config for H323.
Please rate if it is helpful...
I'm not using CUCM and we don't want to. I just want to use H323 but it seems the system is enabling SIP by default.
h.323 is an old protocol and should not be used on new systems. Use SIP instead.
Even if you make it work it won't be probably supported by Cisco.
Thanks. It's a DoD sponsored network so I don't have any choice there.
Alwin,
Make sure under Provisioning, within the codecs webpage, that you set the mode to "Off".
Justin
Justin Ferello
I do, every time. But when it restarts 'Auto' is turned back on.
Try disabling CDP and Voice VLAN and see if that helps.
Justin Ferello
No luck.
Provisioning set to 'Off'. CDP, SIP, and Voice VLAN are Disabled. H323 is enabled and manually configured and it registers. However, upon a restart...everything is undone.
Hello Alwin,
Try downloading the same software from cisco.com and perform a software upgrade image with same and again try.
Sometimes re-imaging fixes the issue.
Thanks.
Wayne DeNardi
VIP Advisor
Wayne
Thank you Wayne!
We discovered that it was a network VLAN issue that was actually affecting all of our endpoints to various degrees.
Content for Community-Ad
Spotlight Awards 2021
