ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Speaktrack60 Firmware upgrade fail after RoomKit PRO firmware upgrade
we upgraded the firmware of the Room Kit PRO to the latest 9.13 version, however the speakertack60 firmware failed and shows the error as attached.
Any idea how to fix this? It says "Connected peripheral has incorrect software version"
1 REPLY 1
Highlighted
VIP Advisor
Re: Speaktrack60 Firmware upgrade fail after RoomKit PRO firmware upgrade
How did you upgrade the endpoint, did you do it via CUCM, or TMS, or the Web Interface?   Depending on how you did it, the reason it didn't upgrade fully may be different.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
