stack 5310 and 5320 together
jarrod sousa
is it possible to stack a fully licensed 5310 and a fully licensed 5320 MCU together to make a single 30x 720p30 port MCU?
thanks!
Patrick Sparkman
Yes it is possible, there is a document/powerpoint somewhere that shows the different scenarios, but I can't remember where I've seen it at.  Basically to my understanding, you can stack any combination of the two up to a max of two MCUs.
jarrod sousa
Dude this is exactly what I needed! thanks a ton for digging this up.
Sent from Cisco Technical Support Android App
