Strange Message on Cisco Room Kit Plus registered to CUCM
twegmans
Greetings All,
This is a strange one - I have a new Cisco Room Kit Plus running ce 9.1.3 75ff735 2017-07-10 code registered to a CUCM running 10.5.2.12901-1.
Intermittently, I am getting the message on the display in the attached picture.
It is usually after stopping a presentation - but on different laptops - so I dont think its the laptop or something unique running on a laptop.
I am not able to recreate it every time after stopping a presentation.
I know its not the AI for Spark assistant. I have a TAC case open but looking to see if anyone in the community has seen this before.
Thank you!
5 Replies 5
Patrick Sparkman
I've never seen that message before, nor know of anyone who has. I checked the admin guides etc, didn't find any mention of that type of message appearing on the screen. MIght be worth contacting TAC to see if they can tell you.
I did open a TAC case - and at first they thought it had nothing to do with the AI 'Hey Spark' stuff - but in the hidden Experimental that option was turned on.
Turned it off - all good now.
What was the exact setting? I don't see anything in Experimental for Spark in CE9.2.3
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
The setting is likely the Experimental > General Settings > VoiceControl Enabled: On
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
 In the version of CE code I was using Experimental was hidden. But accessible if I searched for experimental.
