Switch firmware on CTS-1300
Syed
Level 3
Level 3
Dear All,
May I ask you how to switch firmware version on CTS-1300 through cli?
Thank you
Syed
2 Accepted Solutions
Try utils system switch-version
Refer following URL for more information,  http://www.cisco.com/c/en/us/td/docs/telepresence/tx_sw/6_0/command_ref/tx_sw_cli_book/tx_sw_cli_cmd_utils.html#26829
Hi syed,
you can login to the CLI of the CTS and give command ütils system switch-version.
You can also be specific and do slot switching by giving command utils system switch-version force 2
. If you do not configure an optional value, the system will toggle between slots 1 and 2. If the system is currently in a call, the version change will not be allowed. To override, use the force option to switch immediately.
It is not recommended to switch the version during the live call.
Syed
Level 3
Level 3
I want to switch from slot1 to slot2
Please see below show version output
admin:show version
primary
Factory CTS 1.9.2(19) P1
*Slot 1 CTS 1.9.2(19) P1
Slot 2 CTS 1.10.7(5) P1
loads file information
Factory (cmterm-CTS.1-9-2-19R-K9.P1)
CTS: CTS.1-9-2-19R-K9.P1.sbn
Touch: CTSDEV.1-9-2-19R-K9.P1.SPA
Slot 1 (cmterm-CTS.1-9-2-19R-K9.P1)
Slot 2
No loads file
Thank you Navid & Prasad.
Learnt a new thing.
Hi syed,
