Sx 20 integration with Huawei
Yasir Vistro
Beginner
Beginner
hi All
I like to register sx20 with software version TC 5 on Huawei Softx 3000.   From  Huwei to sx20 call successfully establish but sx20 to Huwei to sx20 call not connect.
Yasir Vistro
Yasir Vistro
6 REPLIES 6
saad alam
Beginner
Beginner
if You can call me on number 0092 343 2517610.i will help you on same.
regards
Saad
Saad
i try to call you but your number is not responding ..
Yasir Vistro
Yasir Vistro
Do you have call log from SX20 to Huwei which help us to understand where call negotiation failing.
BTW, if you disable encryption on SX20 (xConfiguration Conference 1 Encryption Mode:off), do you see same result as well on call initiating from SX20?
2488.02 IXUser I: iXController(0x43026948) registerProtocolUser: proto=1, user=0
x430271d8
2488.02 IXUser I: iXController(0x43026948) registerProtocolUser: proto=2, user=0
x43001588
2488.02 MC I: Experimental 1080p60 is configured on this box
2488.04 MC I: Conference::addRemoteParticipant(p=43,ch=3) adding modecontrol sha
red channel
2488.04 MC I: Conference::modeChanged(c=34) holder=-1  Video (3): vid-off 0x0@0.
0  0k
2488.04 MC I: RemoteParticipant::outgoingDuoModeChanged(p=43, ch=3): ModesContro
ller wants to run mode: Video (3): vid-off 0x0@0.0  0k
2488.05 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=1
2488.05 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialize
d 1
2488.05 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 1 w 1920 h
1080
2488.05 RTP I: SockPair::dynamic(sock=0) retrying next pair (rtp port=2408)
2488.06 RTP I: SockPair::dynamic(sock=1) retrying next pair (rtp port=2410)
2488.06 RTP I: SockPair::dynamic(sock=2) retrying next pair (rtp port=2412)
2488.06 RTP I: SockPair::dynamic(sock=3) retrying next pair (rtp port=2414)
2488.06 RTP I: SockPair::dynamic(sock=4) retrying next pair (rtp port=2416)
2488.06 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=19
2488.06 DATACTRL I: DataGateAddReq(ig=42) assoc gate -1 hdlc=yes
2488.14 VIDEOROUTER-0 W: VideoRouter_Ready_doVIDDelayInd: No gateid 4 from FSPRO
XY_FSM 9
2488.15 MC I: MediaServerAction(): InputGate(ig=601) creation took 108 milisecon
ds
2488.16 MC I: MediaServerAction(): InputGate(ig=609) creation took 114 milisecon
ds
2488.17 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=381/60/0/4577
2488.25 RTP I: TrafficCtrl: Added new entry (main): id: 404, tcid: 65568
2488.27 MC I: MediaServerAction(): InputGate(ig=604) creation took 226 milisecon
ds
2488.28 RTP I: TrafficCtrl: Added new entry (duo): id: 406, tcid: 65568
2488.32 MC I: MediaServerAction(): InputGate(ig=607) creation took 276 milisecon
ds
2488.34 RTP I: TrafficCtrl: Added new entry (duo): id: 410, tcid: 65569
2488.39 MC I: CallParticipantImpl: calledUri: sip:65787@10.252.141.65
2488.39 SipCall I: ==== makeOutgoingCall appId=43, stackId=na
2488.40 MC I: Experimental 1080p60 is configured on this box
2488.43 MC I: RemoteParticipant::proposeMode(p=43, ch=1): Did not find mixer ((n
il)) or channel (0x430019e4)
2488.43 MC I: RemoteParticipant::propose60fpsThreshold(p=43, ch=1): Did not find
mixer ((nil)) or channel (0x430019e4)
2488.43 MC I: RemoteParticipant::reevalRefMode(p=43,ch=1) set ref [Audio (1): G.
711a  64k ] q= auto, t60=6000
2488.43 MC I: RemoteParticipant::reevalRefMode(p=43,ch=2) set ref [Video (2): vi
d-off 0x0@0.0  0k ] q= auto, t60=6000
2488.43 MC I: RemoteParticipant::reevalRefMode(p=43,ch=3) set ref [Video (3): vi
2488.43 MC I: RemoteParticipant::proposeMode(p=43, ch=4): Did not find mixer ((n
il)) or channel (0x430271bc)
2488.43 MC I: RemoteParticipant::propose60fpsThreshold(p=43, ch=4): Did not find
mixer ((nil)) or channel (0x430271bc)
2488.43 MC I: RemoteParticipant::reevalRefMode(p=43,ch=4) set ref [Data (4): H.2
24-HDLC  64k ] q= auto, t60=6000
2488.43 MC I: RemoteParticipant::reevalRefMode(p=43,ch=5) set ref [Video (5): vi
2488.43 MC I: MediaServerAction(): InputGate(ig=611) creation took 383 milisecon
ds
2488.43 SipCall I: sip_call_handler::handleSIPMRtpLocalCapsetInd(43/-1/-1, capse
tentries: 23): Received local capset with payload types set
2488.43 MC I: RemoteParticipant::configureIncomingChannel: Capability table:
1: (2) H.264 maxbr=6000000 maxfs=9000 maxmbps=490000 maxsmbps=490000 maxfps=600
0  [97]
2: (2) H.264NIL maxbr=6000000 maxfs=9000 maxmbps=490000 maxsmbps=490000 maxfps=
6000  [98]
3: (2) H.263PP maxbr=3000000 fps-qcif=3000 fps-cif=3000 fps-4cif=3000 fps-sif=3
000 fps-4sif=3000 fps-vga=3000 fps-svga=3000 fps-xga=3000 fps-wcif=3000 fps-w4ci
f=3000 fps-w720=3000 fps-wxga=3000  [99]
4: (2) H.263 maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=1500  [34]
5: (3) H.264 maxbr=2000000 maxfs=8160 maxmbps=122500 maxsmbps=122500 maxfps=300
0 feat=Pres-Token  [97]
6: (3) H.264NIL maxbr=2000000 maxfs=8160 maxmbps=122500 maxsmbps=122500 maxfps=
3000 feat=Pres-Token  [98]
7: (3) H.263PP maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=3000 fps-sif=3
f=3000 fps-w720=3000 fps-wxga=3000 feat=Pres-Token  [99]
8: (3) H.263 maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=1500 feat=Pres-T
oken  [34]
9: (1) AAC-LD rate=128k profile=25  [100]
10: (1) AAC-LD rate=64k profile=24  [102]
11: (1) G.722.1 rate=32k ptime(ms)=40  [103]
12: (1) G.722.1 rate=24k ptime(ms)=40  [104]
13: (1) G.722 rate=64k ptime(ms)=40  [9]
14: (1) G.711a rate=64k ptime(ms)=40  [8]
15: (1) G.711mu rate=64k ptime(ms)=40  [0]
16: (1) RTP-Dtmf  [101]
17: (2) RTCP-Feedback-PLI
17: (2) RTCP-Feedback-FIR
17: (3) RTCP-Feedback-PLI
17: (3) RTCP-Feedback-FIR
18: (3) H.239Ctrl
19: (4) H.224-HDLC  [105]
19: (4) H.224  [105]
Simcapset:
(1) {9,10,11,12,13,14,15,16}{1,2,3,4}{5,6,7,8}{19,19}
2488.44 DATACTRL I: DataGateCfgReq(ig=42) hdlc=yes
2488.46 SipStack I: NETConnectRej: failure as OS level
2488.47 SipStack I: NETConnectRej: failure as OS level
2488.47 MC I: VideoInputGateImpl::inputGateConfigState(ig=604): DecoderConfig[60
4]: maxMbps: -1 maxWidth: 1920 maxHeight: 1200 memsize: 1
2488.70 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=381/60/0/4578
2488.97 SipStack I: NETConnectRej: failure as OS level
2489.11 MC I: RemoteInputGateImpl::setIncomingModeReport(ig=601,p=43) [Audio (1)
: aud-off stereo  0k ]
2489.22 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=381/60/0/4580
2489.74 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=381/60/0/4579
2489.97 SipStack I: NETConnectRej: failure as OS level
2491.97 SipStack I: NETConnectRej: failure as OS level
2495.97 SipStack I: NETConnectRej: failure as OS level
2503.96 SipStack I: NETConnectRej: failure as OS level
2503.97 SipStack I: NETConnectRej: failure as OS level
2507.07 SipCall I: ==== outgoingDisconnect appId=43, stackId=-1, eventCookie=-1,
(sipCause.dc=8, sipCause.status=0)
2507.07 SipStack !ER SIP_ASSERT, File: functional/protocols/sip/sipuafsm.c, Line
1957
2507.07 SipCall I: sip_call_handler::handleSIPMDiscCnf(43/-1/-1): Disconnect con
firm
2507.08 SipStack I: NETConnectRej: failure as OS level
2515.06 MC W: TransactionActionStorage::cbTimeoutAction: Disconnect callstackid(
43)
2515.10 IXUser I: iXController teardownIxChannel: Not connected
2515.10 MC I: CapabilityControllerImpl::setCapset() reduced = 0, waitForDuoGate
= 0, hasLegacyVideo = 0
2515.12 RTP I: TrafficCtrl: Deleting entry (main): id: 404, tcid: 65568
2515.12 RTP I: TrafficCtrl: Deleting entry (duo): id: 406, tcid: 65568
2515.12 RTP I: TrafficCtrl: Deleting entry (duo): id: 410, tcid: 65569
2515.12 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=20
2515.12 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialize
d 1
2515.13 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 1 w 1920 h
1080
2515.13 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialize
d 1
1080
d 1
2515.13 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 0 w 1280 h
720
2515.13 DATACTRL I: DataGateRemReq(ig=42)
2515.29 MC I: MediaServerAction(): InputGate(ig=614) creation took 187 milisecon
ds
2515.31 VIDEOCTRL-0 I: VIDEOCTRL_doReadyMixerConfigureReq: redundant signal for
mixer (rawvideo,1) from (MSCtrl,0)
mixer (rawvideo,2) from (MSCtrl,0)
2520.44 MC W: Mcfsm::handleOtherMessages() unknown msg SIP_DialogFreed_Ind from
SipStack
Yasir Vistro
Yasir Vistro
The call log from SX20 doesn’t contain any error or useful log identify the call connection problem.
However possible issue relate with CapSet size. Huawei Endpoint may not handle large CapSet from SX20 (Endpoint team has seen this before).
Try using CapSet filter command on SX20 to reduce CapSet offering to Huawei Endpoint and see whether this may help resolving your call connection issue.
mmehrota
Hi All
Is SX20 supported through Huawei VP9620 MCU?
Pls help
thx
Manas
