11-25-2012 06:04 PM - edited 03-18-2019 12:11 AM
We want to use SX 20 with crestron controller(using RS-232)
Before, we used C20 with RS-232 controller using Y Cable
But SX20 don't have RS-232 port
Can i use SX20 with RS-232?
Regard
Solved! Go to Solution.
11-25-2012 10:22 PM
you can use the USB port on the SX20 to connect a USB to serial cable. Once the SX20 is booted, you should get the RS-232 activated. It runs at a speed of 115200. You will not get any connection in the early boot process including U-boot. Only when system is fully booted, the port will be active. The RS-232 presents itself as a DTE. I do not know what the CRESTON expects. Should it be a DCE, you are OK, if not, a null-modem will be required. Have not tried to use the USB port on the SX20 myself. Will give it a shot and test it.
11-25-2012 10:23 PM
11-25-2012 10:22 PM
09-14-2017 02:11 PM
Do I need to manually enable usb port so that I can do serial communication from web interface settings?
I have been trying to control SX20 codec for last two days, but no luck. I am using Extron DTP Crosspoint 864K in order to control this SX20.
Any guidance will be appreciated. I am stuck
Thank you,
Kuntal
09-14-2017 06:30 PM - edited 09-14-2017 07:19 PM
By default the serial port is enabled.
You can check your settings though on the web interface under Setup > Configuration > SerialPort.
Note: the default speed is 38400, not 115200 mentioned in an earlier post. You can change it on the Setup screen if you need to and to make sure it matches what your other device is set to.
Please remember to mark helpful responses and to set your question as answered if appropriate.
09-17-2017 04:55 PM
Yes, I did all this. But still I can not control Cisco SX20. I will take one moe shot with different USB to serial adapter cable and hope it will magically work. This is very frustrating. Please let me know if you still have any other suggestions. I will try those too
09-17-2017 08:45 PM
Make sure your USB->Serial adaptor is using one of the supported chipsets.
From memory the PL2303 and FTDI ones are the oners to look for.
09-17-2017 04:51 PM
I somehow can not control Cisco SX20 with Extron D50 using DTP Crosspoint 864K inbuilt controller IPCP Pro350. I am using USB to serial adpater on SX20 side - female to female DB-9 adapter - TX,RX, and ground going to COM port of IPCP pro 350. Even I called Extron few times, but they couldn't even solve this issue. Any suggestins will be greatly appreciated.
11-25-2012 10:23 PM
11-26-2012 04:57 PM
it is solved with your help.
thanks your help.
