02-05-2016 01:54 PM - edited 03-18-2019 05:32 AM
Greetings
I have a new SX20 that was just installed and the microphone is stuck on red. It is NOT muted and you can mute a call from the touch panel. I press the mute/unmute on the mic and it makes no difference.
Anyone have any ideas/suggestions?
Thank you in advance
02-05-2016 03:24 PM
What software version is the SX20 running, and was it recently upgraded or downgraded?
It sounds like you might be hitting bug CSCux85199, also see cisco_ce800_deferral_notice. It's seen if an SX20 was running CE8.0 and later downgraded to TC7.3.x, or even with some new SX20s shipped with TC7.3.x.
02-05-2016 03:27 PM
Thanks for your reply. Our version is TC7.3.4, so it does not sound like the bug would be the cause but I could be wrong. Any other possibilities?
02-05-2016 03:42 PM
It still could be, in the TC7 Release Notes for TC7.3.5 which is the fix for that bug, it said that even some new SX20s that ship with TC7.3.x can have it. Could you upgrade to TC7.3.5 and see if the issue is still there? If that doesn't fix it, you might have an issue with the microphone and maybe need to RMA it, at that point you should contact TAC.
02-08-2016 06:20 PM
As [@patrick.sparkman] wrote, yes, it is still likely that your endpoint is affected by one of the circumstances that cause the microphone mute button issue discussed in that bug. The downgrade process from CE isn't the only thing that brings out this issue. I'd suggest that you upgrade to TC7.3.5 which should resolve the problem, then you can downgrade back to TC7.3.4 (or earlier) if you really want to.
The symptoms of the above problem are:
This seems to affect SX20s with mainboard hardware version [B0] more than any other version.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
02-16-2016 01:13 PM
Greetings
I upgraded the SX20 to TC7.3.5.a93bdb1 and the issue continues.
Not sure if this is a microphone issue or codec or both. Obtaining another mic and I am going to saw the original one out for the new one. Beyond that, the only other thing I can think of is to factory reset and start fresh.
Any other idea?
02-16-2016 02:06 PM
One way to tell if it's a codec or microphone issue, is to swap the microphone with a known working one. Depending on if the issue follows the microphone or stays with the codec, you'll then know where the issue is. If it follows the microphone, then contact TAC for an RMA. If it stays with the codec, then perform a factory reset to see if it resolves the issue, if that still doesn't resolve it then contact TAC for an RMA.
02-16-2016 04:55 PM
check for this bug as well
02-16-2016 06:01 PM
You could also try updating to CE8.0.1 to see if that fixes the microphone - then downgrade back to TC7.3.5 afterwards.
Wayne
05-12-2016 12:23 AM
Given that all those earlier TC7 releases have now been deferred, an upgrade to TC7.3.6 is recommended to fix this issue. I have done that on a couple this week and can confirm that it does solve the problem on those endpoints that are behaving as I described previously.
Wayne
01-31-2017 02:56 PM
I may have a SX20 with the same problem. I see in your post that 7.3.6 is a possible fix, but I am currently running 7.3.6 (Current versionTC7.3.6.ea51021)so have you seen any reports of the issue on that version?
01-31-2017 03:18 PM
I have seen it happen a couple of times on the newer software releases when an end user has damaged the microphone cable, breaking or shorting the wiring inside.
In this case, the microphone needs to be replaced.
Wayne
