05-07-2017 09:05 PM - edited 03-18-2019 01:04 PM
SX20 is in Singapore,cucm core is in Beijing.
I have put rootCA cert in the SX20 already.
Set NTP and DNS(local) already.
Username and password was imported from LDAP.
SX20 can not registered.
05-07-2017 09:36 PM
1. Can you please confirm if you have configured the Endpoint in edge mode as per the guide below?
http://www.cisco.com/c/en/us/support/docs/unified-communications/expressway/118696-config-cucm-00.html#anc11
The mode should be set to edge and the Expressway E's entry should be added.
2. Also, share the output of the following:
xstatus //prov
3. Can you check on the CUCM if there is any trunk created on CUCM towards the Exp-C? If there is a trunk then change the listening port to some other port?
4. Also, make sure that you are able to login to the ccmuser page? You can use the below URL:
https://IPOFCUCM/ccmuser
5. Can you check if you are using a secure Phone security profile on the CUCM. If you are using a secure profile then you will need to create a new CSR on the expressway C and include the FQDN of those profiles as SANs on the CSR and send it off to be signed for a new cert. Also, try registering it by using a non-secure profile to check if you get a different result.
Aseem Anand
05-07-2017 10:19 PM
Thank you very much
05-08-2017 01:40 AM
Look at this document, i think it will help you.
Don't worry about the software version.
Alok
05-08-2017 06:50 PM
Appreciate it. I have figured it out.
05-08-2017 02:28 AM
you are most welcome! Let me know if the steps help you fix the issue and rate the helpful posts.
Aseem Anand
