06-15-2012 08:17 AM - edited 03-17-2019 11:19 PM
We have several new SX20 units, two of which I have setup and registered via SIP with UCM (v8.6.2, required a device pack). I can place a call to the SX20 from a regular IP phone (7961 - SCCP), answer the call with the telepresence unit and carry on a voice only conversation. However when dialing from the SX20 to another SX20 or any other IP phone it briefly displays "connecting call", then immediately goes to "call has disconnected". I have tried dialing just the 4 digit DN, as well as the SIP URI. Below is a portion of the command line log output for the sx20 that indicates the SIP call is being rejected with a 403 forbidden message.
It should be noted that prior to these devices, we had no phones registered via SIP, only SCCP. At this point, these devices do not need to dial outside of our network. I've had a TAC case open for two weeks, and keep getting passed between Telepresence and UCM teams. I told them we've never had a SIP device registered with our UCM before and if there was anything else that needed to be configured, the answer was nothing more for internal calls only. I am in the process of trying to get it escalated now, but thought I would give the forums a go. Any help is greatly appreciated, and I apologize if this issue is something is something ridiculously simple.
63018.74 DATACTRL I: DataGateCfgReq(ig=7) hdlc=yes
63018.76 SipStack I: SipDialog(ui=8,s=0) sendInviteRejToStack (403:Forbidden)
63018.76 MC W: Mcfsm::handleOtherMessages() unknown msg SIP_DialogFreed_Ind from SipStack
63018.77 SipCall I: sip_call_handler::handleSIPMCallRej(8/0/-1): Call rejected (cause: Forbidden)
63018.78 MC I: signalLocalReceiveCapsetChange, RemoteParticipant::signalLRCap
63018.78 SipCall I: ==== makeOutgoingUpdate appId=8, stackId=-1, eventCookie=-1, isEmptyCap=0, holdState=0
-JW
Solved! Go to Solution.
06-15-2012 12:25 PM
Took a look at the logs on your case - looks like there is no calling number passed in the RPID or Contact header, so CUCM rejects the call and sends the 403 forbidden. Note the "From" field below - should be sip:1070@XX.XX.XX.XX. What do you have configured as your SIP URI in your SX20? Not that familar with the SX20, but on my EX90 in the lab, there's a SIP URI field that I had to enter the DN@
primaryDN=1070, Cannot get calling DN to determine the LineControl...sending 403
SIP/2.0 403 Forbidden
Via: SIP/2.0/TCP XX.XX.XX.XX:5060;branch=z9hG4bK8664f3a10726dfcdd3f6437593e431b6.1;rport
To: <>>1091@XX.XX.XX.XX>;tag=1701792190
Date: Thu, 14 Jun 2012 16:56:46 GMT
Call-ID:
CSeq: 100 INVITE
Allow-Events: presence
Warning: 399 CM2 "Unknown calling DN"
Content-Length: 0 SIP/2.0 403 Forbidden
Call-ID: 143a225a97ecefc2@XX.XX.XX.XX
CSeq: 100 INVITE
Content-Length: 0
06-15-2012 09:40 AM
Can you please tell the SR opened with TAC. We can have a look and revert.
Also i believe you have already checked partitions and css config on cucm.
Amlesh
06-15-2012 11:00 AM
Thanks for your reply Amlesh, the case is SR# 621972909. I did check the css config and partition on cucm. They are set to partitions and css that we normally use, but I tried several others with no noticable effect on the issue. Thanks again.
06-15-2012 12:25 PM
Call-ID:
CSeq: 100 INVITE
CSeq: 100 INVITE
Content-Length: 0
06-15-2012 01:02 PM
Thanks for your reply. The SX20 also has the SIP URI field. When I initially opened my Service Request that was the first thing I asked, what I needed to put in that field. The response I got was that it was just an identifier and it didn't matter what format it was in, etc... So, previously I just had the DN as the SIP URI. After replacing it with 1070@XX.XX.XX.XX, the call went through just fine. I had a feeling it was something simple, so thank you for clearing that up I greatly appreciate it.
