09-14-2016 08:20 AM - edited 03-18-2019 06:22 AM
Hello.
On the SX80, is there a way to enable Do Not Disturb mode from the web GUI?
We are running TC software. On the C-series codecs, this setting is available, and there is an on-screen indicator showing whether it is enabled or not both during and outside of a call.
Unfortunately, the SX80 only has an on-screen indicator outside of a call. A custom programmed AMX touch panel has a button to toggle the setting, but once we are in a call, we don't know whether DnD is enabled or not. So it would at least be helpful if we could see the current state of DnD and/or set it to Do Not Disturb through the web GUI.
(Other than using API commands which is what I am hoping to avoid.)
09-14-2016 11:15 AM
HI Jeremy,
There is no way to enable DND from Web-GUI, while it can be done from CLI by following command:
xConfiguration Conference DoNotDisturb Mode : <Off/On/Timed>
The DND status can be checked from Web-GUI in following manner:
Navigate to Configuration > System Status > Conference :
There you can find DND status in the first option.
Below is the image, for reference :
Rishabh Gupta
09-14-2016 12:03 PM
Because the SX80 doesn't show the DND status on the monitor, since it uses the Touch 10 to show this, you should show the status using your AMX touch panel instead. Ideally the AMX programmer should have the DNS button set to be showing proper feedback from the SX80 to reflect it's status when active/inactive.
The API command to get the DND status is:
xStatus Conference DoNotDisturb
Please remember to rate responses and to mark your question as answered if appropriate.
