Is the CAB-MIC20-EXT compatible with CS-CODEC-EQ- K9+?
The content you are looking for has been archived. View related content below.
We have one conference room with a Cisco Room Kit and a Touch10 connected with the MSTeams app on the home screen. The other conference room has an SX80 codec with another Touch10 tablet except this room's tablet does NOT have the Teams app. What is ...
Is there a way to automatically stop sharing PC or laptop input after people leave the meeting. The system will not go into standby when pc or laptop is shared and room scheduler is lit up red as the room is being used. Is there some kind of macro ...
I have cms 3.2 installedI have successfully installed the certificate chain which has client and server authentication.The webbridge3 url is not displaying any web page.error: c2w://cms.domain.com:9999 connection failed ..i have not been able to see ...
Hi, we have a configuration with a Cisco Sx80 + Touch 10, 2 cisco P60 cameras, and a Creston 300 with an Android tablet and Creston Go Software.The monitors, Android Tablet, the Creston, are on a switch with a 172.xxx subnet and the cameras and the t...
Hey there, we are currently setting up different Cisco devices (Room Bar, Board Pro,..) as MTRoA-devices. We have a Teams Rooms Pro license applied to each Teams-resource account and i am wondering what is the best effort for the firmware management ...
Looking for some help as I'm not really sure where to go. I have one particular site that seems to experience poor video quality quite frequently and sometimes poor audio quality as well. The site is connected via 100Mbps MPLS and by my analysis is...
Hello Everybody, Scheduler 3.3 Beta is available natively with CMS (what a relief!) and works perfect (so far) with fantastic features (one of them: invite all coSpace members with one checkbox!).But does anybody know how to modify email template for...
Hello Everyone,I have cms 3.4.1 and cmm.3.4I have modified the email template using the emai template i downloaded from cisco website.Unfortunately, when i copy the email invite,it still shows the cisco default email template. The same happens if i t...
Hello, I have a Cisco Room Bar Pro running MS Teams Rooms (MTRoA) connected to two external displays in a conference room. when not in a call (local in person meeting) and share content from my laptop via HDMI, it only allows content on 1 screen and ...
I have two room kit EQ units with a USB to serial port adapter. This is connected to a Crestron controller via RS232. I am not getting RX response from the codec. The user LOGIN REQUIRED has been tested with ON/OFF. The baud rate and settings have be...
We have many Webex Room Kits throughout our institution and are in the process of moving to OS 11.9.3.1. Since moving to OS11, we've needed to disable the On Screen Display (OSD) in order to properly show a wallpaper with instructions for using the s...
I have developed a script used for managing goasted meeting rooms that uses a check-in process and timer to decline meetings where there are no -shows after 10 minutes. The script also asks users if they want to free up the room at the end of a meeti...
Hi thereTwo conference rooms are equipped with CISCO WEBEX CODEC PLUS in each.The system administrator has confirmed that both systems share identical configurations and firmware.However, one of the touch panels is not displaying the microphone symbo...
Hi All, I have 3 nodes of CMS in cluster with 2 nodes having callbridge ad webadmin role and 3rd node acting as a Primary database node. Referring all the release notes understood that I would need to go through 5 step upgrade as 2.8 >> 2.9 >> 3.0 >>...
Subject | Author | Posted |
03-28-2024 08:12 AM | ||
03-27-2024 06:24 AM | ||
03-26-2024 08:37 AM | ||
03-22-2024 10:12 AM | ||
03-20-2024 09:29 AM |
