Walkthrough Wednesdays
634
mlong0000
Beginner
Tandberg Edge 95 MXP with CUCM
I'm wondering if anyone has Tandberg Edge 95 MXP devices working on CUCM?
I have a bunch of Tandberg Edge 95 MXP devices that are currently registered to VCS and I want to migrate them to CUCM. I have tried on CUCM 10.5 and also CUCM 12.0.
The devices register ok as 3rd party SIP devices and calls are establishing. However on the call I am not getting any video. It's audio only at 64K. To keep things simple I have the device in the same region/location as the other devices (Spark Room Kits, Jabber, SX20) that I'm testing with and the test calls are point to point direct calls. Calls between these other devices are working ok.
On the old setup of the Tandberg, H323 calls are working fine so there is no issue with hardware.
Michael
1 ACCEPTED SOLUTION
Did you add them as Adcanced 3rd Partry SIP phones? CUCM strips video SDP capabilities from the Basic 3rd Party device type.
2 REPLIES 2
Hi Jonathan,
yep that looks to have done the trick. I can see video traffic passing ok now.
Content for Community-Ad
Spotlight Awards 2021
