07-30-2013 03:43 PM - edited 03-18-2019 01:32 AM
DOes anyone know where I can find a tandberg ttc7 manual online? I have searched quite extensively.
THanks!!!
07-30-2013 05:50 PM
I think more or less all the Tandberg style endpoints are TTC systems, do you have a name
(like MXP3000, C60, ...) or at least an index (like a c20 is a TTC7-18)
07-31-2013 07:14 AM
TTC7-08 is all that I can get off of it
07-31-2013 07:24 AM
Rod
Have you tried using Google or the search engine of your choice?
A search for "TTC7-08 manual" - without quotes will give you a multiple repsonses with links to the relevant manual for you to download.
In this case for the TANDBERG 770/880/990MXP
c/
07-31-2013 09:34 AM
Yes I saw results come up for 770/880, but I was not aware that was the same as ttc7-08. Thanks!
