11-30-2016 10:00 AM - edited 03-18-2019 06:38 AM
I have the Tandberg VCS controller and endpoint running on x8.2.2 can I upgrade to the latest version of 8.8.3?
Solved! Go to Solution.
11-30-2016 10:41 AM
It depends on the VCS platform, you should refer to Table 2, Supported Platforms, in the VCS X8.8.3 Release Notes to see what software versions are supported on what platforms. Some software versions are only supported up to a certain hardware platform.
11-30-2016 10:41 AM
11-30-2016 11:18 AM
Thanks Patrick I did check the release notes and I am able to install the x8.8.3 but TAC will only support up to x8.6.1 the equipment that I have is 1st generation.
thanks again,
Randy Haddon
