07-22-2014 06:55 PM - edited 03-18-2019 03:12 AM
The local and remote layouts are created under the same name, but it appears that they are menu selected separately. I would have liked to have both activated together using the layout button via IR remote. Is this correct that the only way the remote layout changes is via the soft-key labeled Remote layout?
Also found the remote layout holds the last selected one even when a new call causes a new default to be active. You need to activate the last used one, then you need to select a different one then reselect the original.
Solved! Go to Solution.
08-13-2014 08:20 PM
Hi Joel,
I don't think there's any easy way you can switch both layouts simultaneously with the Remote.
For all the purposes we need to do this, we use the Compositor API functionality from an external control system to change both the local and remote layouts.
I'd suggest if you really need to be able to do this with the remote that you log a Feature Request through your Cisco Account Manager for possible inclusion in a future release.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
08-13-2014 08:20 PM
Hi Joel,
Wayne
08-15-2014 07:12 AM
One additional anomaly I have, the custom layouts do not all consistently show up in the menu for local choices. Sometimes more will show up (not in a call) when I rearrange the menu order or when I include a predefined layout (Equal). Note I have three cameras on a C90 and the problem layouts seem to be ones using a single camera. Also when in a call fewer yet local layouts show.
