02-11-2014 04:33 AM - edited 03-18-2019 02:34 AM
Does anyone know how to bypass or allow iframes for Cisco TelePresence SX20, C40 using TC7.0
We were able to display snapshots using iframes on TC5.1 but it's now no longer working with TC7.0
Any help is greatly appreciated. Maybe there's a way to re-enable this setting on the web server of the VC unit?
Solved! Go to Solution.
02-11-2014 07:37 PM
One easy (but not necessarily secure) way is to add the credentials in to the URL, ie:
http://username:password@x.x.x.x/websnapshot/get
The refresh can be done within the HTML HEAD element, ie to refresh every 30 seconds:
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-11-2014 02:54 PM
From TC6 the path for the websnapshot changed from /wsgi/translation to /web/translation. That may be your issue.
Edit: Sorry, the above was for the touchpanel snaptshots... the websnapshots are at /websnapshot/get
Note: the websnapshots must be enabled on the device - I've seen the odd one or two loose this setting following an upgrade and it having to be re-enabled on the device.
Wayne
02-11-2014 07:00 PM
Thanks for your reply Wayne.
I did notice that the URL was changed from wsgi to web however the login page still does load in an iframe.
Debugging using Chrome Dev console I get:
Refused to display '
http://xxx.xxx.xx.xx/web/signin?next=/web/call
' in a frame because it set 'X-Frame-Options' to 'DENY
02-11-2014 07:06 PM
Is there a reason you're going to that URL ant not just directly to "http://xxx.xxx.xx.xx/websnapshot/get" for the snapshot?
Wayne
02-11-2014 07:12 PM
Wayne,
That was just an example to get the X-Frame-Options.
The same thing happens when going to websnapshot/get or any url on the VC:
Refused to display 'http://xx.xx.xx.xx/websnapshot/get' in a frame because it set 'X-Frame-Options' to 'DENY'.
02-11-2014 07:17 PM
The reason why we are using iframes is because we want to include several snapshots on the one page.
02-11-2014 07:27 PM
I've done similar, but just used a table of the images from /websnapshot/get (and refresh the page very 30 seconds) - lots of:
http://XXX.XXX.XX.XX/websnapshot/get" WIDTH="320" HEIGHT="180" BORDER="1">
Wayne
02-11-2014 07:31 PM
Never thought of using the IMG tag.
That is a winner. How did you automatically authenticate to the VC unit and refreshed the page?
02-11-2014 07:37 PM
Wayne
02-11-2014 07:43 PM
You are a legend Wayne. We will try this method then.
02-11-2014 07:45 PM
Happy to be of assistance.
Wayne
02-11-2014 07:46 PM
Love the Cisco Support Community.
