10-22-2014 02:33 AM - edited 03-18-2019 03:33 AM
Hi, we got the following problem concerning sip calls:
here's the log:
Software Version VCS: Plattform X7.2.3 | Labor X8.2.1
______________________________________________________________________________
Not Working Call with TC 7.2.1
SIPMSG:
|INVITE sip:9209901105@xyz.com SIP/2.0
Via: SIP/2.0/TCP xx.xxx.60.133:57597;branch=z9hG4bK38f566387dbd719702049ddcb2590ebe.1;rport
Call-ID: 4832bd6a60d9d3d43670c55c573667ec
CSeq: 101 INVITE
Contact: <sip:201101102@xyz.com:57597;gr=urn:uuid:6c856033-4cbd-5b15-bb13-0715c4a694cd;ob>
From: "201101102_C40_ServiceDesk" <sip:201101102@xyz.com>;tag=d25377890df67530
To: <sip:9209901105@xyz.com>
Max-Forwards: 70
Route: <sip:xx.xxx.1.51;lr>
Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,REFER,NOTIFY
User-Agent: TANDBERG/521 (TC7.2.1.cb31c3d)
Proxy-Authorization: Digest nonce="bb1d830b2d64949caaadfb732cd7ca77414a991699854e8971970a68fe06", realm="tplabvcsc01.xyz.com", qop=auth, opaque="AwAAAMSaxlh37+YNQULdXHDdMkXYHVQ1", username="", uri="sip:xyz.com", response="51f225da16a3ac710e86c1b1b5815438", algorithm=MD5, nc=00000008, cnonce="21c839c8313e8f7f7477786cb40c5ee6"
Supported: replaces,100rel,timer,gruu,path,outbound
Session-Expires: 1800
Content-Type: application/sdp
Content-Length: 2842
v=0
o=tandberg 6 2 IN IP4 xx.xxx.60.133
s=-
c=IN IP4 xx.xxx.60.133
b=AS:6000
t=0 0
m=audio 16424 RTP/AVP 107 108 109 110 104 105 9 15 18 8 0 101
b=TIAS:128000
a=rtpmap:107 MP4A-LATM/90000
a=fmtp:107 profile-level-id=25;object=23;bitrate=128000
a=rtpmap:108 MP4A-LATM/90000
a=fmtp:108 profile-level-id=24;object=23;bitrate=64000
a=rtpmap:109 MP4A-LATM/90000
a=fmtp:109 profile-level-id=24;object=23;bitrate=56000
a=rtpmap:110 MP4A-LATM/90000
a=fmtp:110 profile-level-id=24;object=23;bitrate=48000
a=rtpmap:104 G7221/16000
a=fmtp:104 bitrate=32000
a=rtpmap:105 G7221/16000
a=fmtp:105 bitrate=24000
a=rtpmap:9 G722/8000
a=rtpmap:15 G728/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 16426 RTP/AVP 97 126 96 34 31
b=TIAS:6000000
a=rtpmap:97 H264/90000
a=fmtp:97 packetization-mode=0;profile-level-id=428016;max-br=5000;max-mbps=245000;max-fs=9000;max-smbps=245000;max-fps=6000;max-rcmd-nalu-size=3456000
a=rtpmap:126 H264/90000
a=fmtp:126 packetization-mode=1;profile-level-id=428016;max-br=5000;max-mbps=245000;max-fs=9000;max-smbps=245000;max-fps=6000;max-rcmd-nalu-size=3456000
a=rtpmap:96 H263-1998/90000
a=fmtp:96 custom=1280,768,3;custom=1280,720,3;custom=1024,768,1;custom=1024,576,2;custom=800,600,1;cif4=1;custom=720,480,1;custom=640,480,1;custom=512,288,1;cif=1;custom=352,240,1;qcif=1;maxbr=20000
a=rtpmap:34 H263/90000
a=fmtp:34 cif4=1;cif=1;qcif=1;maxbr=20000
a=rtpmap:31 H261/90000
a=fmtp:31 cif=1;qcif=1;maxbr=20000
a=label:11
a=answer:full
a=content:main
a=rtcp-fb:* nack pli
a=rtcp-fb:* ccm fir
a=rtcp-fb:* ccm tmmbr
a=sendrecv
m=application 28300 UDP/BFCP *
a=setup:actpass
a=confid:1
a=userid:6
a=floorid:2 mstrm:12
a=floorctrl:c-s
a=connection:new
m=video 16428 RTP/AVP 97 126 96 34 31
b=TIAS:6000000
a=fmtp:97 packetization-mode=0;profile-level-id=428016;max-br=5000;max-mbps=108000;max-fs=3840;max-smbps=108000;max-fps=6000;max-rcmd-nalu-size=1474560
a=fmtp:126 packetization-mode=1;profile-level-id=428016;max-br=5000;max-mbps=108000;max-fs=3840;max-smbps=108000;max-fps=6000;max-rcmd-nalu-size=1474560
a=label:12
a=content:slides
a=rtcp-fb:* ccm fir
a=sendrecv
m=application 16430 RTP/AVP 100
a=rtpmap:100 H224/4800
a=sendrecv
m=application 29789 UDP/UDT/IX *
a=ixmap:0 ping
a=ixmap:2 xccp
________________________________________________________________________________________________
Working Call with TC 7.1.4
SIPMSG:
Via: SIP/2.0/TCP xx.xxx.60.133:37491;branch=z9hG4bKe3dfed840a299516919a79e4a54cd707.1;rport
Call-ID: 480ec504782c0ad894929e882a696e74
CSeq: 100 INVITE
Contact: <sip:201101102@xyz.com;gr=urn:uuid:6c856033-4cbd-5b15-bb13-0715c4a694cd;ob>
From: "201101102_C40_ServiceDesk" <sip:201101102@xyz.com>;tag=3ab87b1c0d8b4d9d
Max-Forwards: 70
User-Agent: TANDBERG/520 (TC7.1.4.908e4a9)
v=0
o=tandberg 3 2 IN IP4 xx.xxx.60.133
s=-
b=AS:6000
t=0 0
m=audio 16394 RTP/AVP 107 108 109 110 104 105 9 15 18 8 0 101
b=TIAS:128000
a=fmtp:101 0-15
a=sendrecv
m=video 16396 RTP/AVP 97 126 96 34 31
b=TIAS:6000000
a=label:11
a=answer:full
a=content:main
a=rtcp-fb:* ccm fir
a=sendrecv
m=application 29489 UDP/BFCP *
a=setup:actpass
a=confid:1
a=userid:3
a=floorctrl:c-s
a=connection:new
m=video 16398 RTP/AVP 97 126 96 34 31
b=TIAS:6000000
a=label:12
a=content:slides
a=rtcp-fb:* ccm fir
a=sendrecv
m=application 16400 RTP/AVP 100
a=sendrecv
m=application 31127 UDP/UDT/IX *
a=ixmap:0 ping
a=ixmap:2 xccp
Another problem, shown in the diagnostics on a MX200-Device, reports NTP issues. I already tried to choose another NTP-Server but this doesnt solve the problem and with TC7.1.4 it's working. In addition the time and the date is wrong on the display but correct on the Touch-device.
Furthermore an error is reported dealing with the OSD-Settings.
You got any advice?
Thanks for helping.
Solved! Go to Solution.
11-24-2014 02:57 AM
Okay, thx for the feedback. I've asked to turn the SIP listenport to 'on'.
I'll keep you informed.
11-28-2014 02:34 AM
Turning on the Listenport is not an option because the endpoint is directly located on the Internet and vulnerable to SIP attacks.
